Storing Boler in the winter - Fiberglass RV
Old 03-27-2015, 09:57 AM   #1
khoa l's Avatar
Trailer: 76 Boler 13 ft
Our boler is located in BC (lower mainland) where there can be lots of moisture in the air during the winter months.
In the past years, when we are not using it we would throw a trap over the boler and store it outside. While this does keep the boler from getting mildew on the outside I find that every year I have to go in with a bottle of Tilex Mold and Mildew remover to clean the inside insolite walls as it gets moldy. Its a couple hrs of scrubbing to get it all clean up again.
What is the best way to prevent mildew when storing outside?
khoa l is offline   Reply With Quote
Old 03-27-2015, 07:29 PM   #2
WildBirder's Avatar
Trailer: 1969 Boler (Flat Top)
Many of us including myself use this chemical dehumidifier.
http://www.walmart.ca/en/ip/dri-z-air-pot/6000016948248
Depending, you may have to refill it a couple times a year.
Mark
1969 Boler
(#183)
WildBirder is offline   Reply With Quote
Old 03-27-2015, 07:44 PM   #3
Cathi's Avatar
POBox 1267, Denison, Texas
You can put a Damp-Rid container or two or similar in there and may need to dump water periodically.
Cathi is offline   Reply With Quote
Old 03-27-2015, 08:55 PM   #4
khoa l's Avatar
Thanks all. I'll pick one up soon. Its really the winter damp months that are the worse. Seeing that spring is here and she'll be sailing soon we shouldn't have any mold issues till the fall.
Old 03-27-2015, 09:26 PM   #5
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
IMHO: DON'T cover it. open (a crack) windows and vent. Keeps humidity level equal to outside conditions...
We're in Maple Ditch close to the Mighty (muddy) Fraser....
Doug Mager is offline   Reply With Quote
Old 03-27-2015, 09:39 PM   #6
khoa l's Avatar
Ha, ha. Yeah, I'm familiar with the 'Ditch'. Problem is if I don't somehow cover it, i'll get mildew stains on the outside plus I'll get pine needles and other depris all over it.
I have covered it and open up the windows and vents but I'm sure its not the same airflow as uncovered.
Old 03-27-2015, 09:44 PM   #7
Byron Kinnaman's Avatar
I guess I lucky or something. I have a nice carport that the trailer get's stored in when not in use. Some windows are open a bit and roof vent is open a bit. Thing I want to do is keep air moving through the trailer. When the trailer was stored like this cold weather I put a space heater inside and kept the temperature over 40°F. This along with Dri-Z-Air kept the mildew out.
Now during cold weather the trailer is in the sunny south soaking up sun while we're getting our vitamin D fix.
Old 03-27-2015, 09:47 PM   #8
khoa l's Avatar
I do have an electric heater that I stuff inside. I think that helps if I'm on top of it. Otherwise the mold starts and once that happens its tough to contain. Maybe the combo heater and Dri-Z will be the trick. Thanks again.
Old 03-27-2015, 10:51 PM   #9
papa-t's Avatar
Trailer: (Dark side)Crossroads Now
Glade Valley, North Carolina
We use the Damp Rid also.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 03-28-2015, 12:43 AM   #10
Cathi's Avatar
You should not put a tarp as that will do more damage than good. You need a breathable cover.
Old 03-28-2015, 12:56 AM   #11
Glenn Baglo's Avatar
My trailer spends the winter ( summer, fall and spring ) under a cedar tree, under the Capilano Cloud, here on the North Shore of Vancouver. You know it's wet here. If I had a choice it would be under a roof, but I don't have that choice.
I have no breathable cover and would never use a tarp.
I have two Dri-Z-Air containers in the trailer ( each is good for about 10 square feet ). I add crystals several times each winter, and dump the liquid collected every week or two. When it warms up, from time to time, I will turn on a small cube heater and crack a window and open the Maxxfan.
All the cupboards are open and cushions etc. are propped up to allow air to circulate. I have no mold in the trailer.
I also have no leaks.
Old 03-28-2015, 09:10 AM   #12
Trailer: 1978 Trillium 4500
We have used one of these in our trilium for the past two winters here in Victoria. We leave one window slightly open. We have a tarp, but it is raised off the top of the trailer by about 6 inches to help with air flow.
CAFRAMO "STORE-DRY" HEATER 110V
The Stor-Dry low wattage warm air circulator is the �must have� product for the winterization season. The model 9406 Stor-Dry combats mold, mildew and musty odors in any boat that is closed up or winterized. This dual action air dryer uses a low wattage heating element and internal fan to both heat and circulate the air. The heat and circulation prevents stale air pockets which in turn prevents mold or mildew forming on the interior surface of the boat.
Part Number: 28-1026
$ 84.95
Old 03-28-2015, 05:35 PM   #13
Trailer: Boler 17 ft
I leave my 17 ft. Boiler outside untarped in these frozen snow covered winters. All cupboard doors, the fridge and bunkers are opened, the seat covers in the house, in plastic. All towels, sheets and clothing and paper stuff in clear garbage bags. Sealed. In the trailer.
At the first sign of impending spring I trudge through the snow and crack open windows, look around and think how lucky I am to have my Boiler.
When it REALLY is spring and after I get over the cold I usually get for jumping the gun, I go into the trailer and spray it with Mold Control that I buy from Home Depot or Home Hardware. I let this sit overnight and then wash it down with dish soap and water.
I do this every year even though there is no mould as a precaution. If there is any painting or touch ups needed I use a mould control paint.
So far, so good.
Linda Stewart is offline   Reply With Quote
Old 03-28-2015, 07:11 PM   #14
khoa l's Avatar
$ 84.95
Interesting product. Will investigate. I've heard through another user that using the Dri-Z-air and refilling it runs him about $60+ a winter. Well, maybe this is a better route.
Old 03-28-2015, 08:19 PM   #15
Not a chance. I bought a large 8 lbs. container of crystals for $19 in the fall and it's still 3/4 full. Maybe you could spend that much buying 4 oz. packets at Camping World.
I had one of those flying saucers shown above. A buddy who has a boat gave it to me. I could see no evidence that it was actually in working condition so I tossed it out.
Old 03-28-2015, 09:13 PM   #16
khoa l's Avatar
Good to know Glenn. $19 and still 3/4 full is sounds alot more reasonable.
boler
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
Storing your Egg Rudy_Z24 Care and Feeding of Molded Fiberglass Trailers 19 02-10-2010 10:57 PM
Storing Awning Pole Carol H Modifications, Alterations and Updates 5 04-30-2009 11:09 PM
Pantry organization- how are you storing your food? Bobbie Mayer Problem Solving | Owners Helping Owners 15 04-30-2008 03:38 PM
Storing security Quint General Chat 4 01-16-2006 10:27 PM
