02-04-2017, 05:10 PM
Trailer: Trillium 1979 13ft.
13' Boler Square Footage
Anyone have the exterior sq. footage of these Bolers? I want to pick up paint to do top and bottom, two coats. The supplier will want to know the area needed to cover. I will do the three steel wheels to match, no door, but fridge and cupboard doors to compliment the exterior! Interlux Brightside is my choice. Thanks, folks!
02-07-2017, 03:03 PM
Square Footage
Surely Somebody has painted their Boler recently?!
02-07-2017, 03:52 PM
Trailer: 13 ft Boler
10 ft long 7 ft. wide 6.5 ft high x 2 coats
less widows about 26 sq. ft.
That will be close enough to get you started.
Once you have used the product you'll get a feel as to weather
you need more or not.
Fred
02-07-2017, 04:39 PM
Square Footage
Hey, thanks Fred. Have you painted a Boler and found these estimates to be fairly accurate?
02-07-2017, 06:57 PM
yes
02-07-2017, 08:33 PM
Square footage
Gee, Fred. So it is 455 minus 26?
02-07-2017, 08:46 PM
Math.
10' long X 6.5' high is 65 sq. ft.
Math.
So, that's one side. Subtract windows, add the other three sides, and the roof.
Although, I did get a D in math 11.
02-07-2017, 08:50 PM
Square footage
We need the width too, correct? This is too much fun! Lol!
02-07-2017, 10:43 PM
Fred
reread
02-08-2017, 01:39 AM
Deep South
10x6x3=180 for the 2 sides & roof, plus 6x6x2=72 for the front & rear, thats 252 minus about 16 for the front & back windows and 8 for the side windows gives you about 228 if I remember the measurements correctly on my 1971 Boler which worked out for fabric for wall coverings and should be about same for paint. I may have rounded those measurements to the nearest foot but I did not come up short, did buy a little extra though. YMMV
02-08-2017, 07:29 AM
Square footage
I see. So these measurements I believe are for the upper half only, since you stated "wall covering" measurements, yes? Almost double that to cover bottom half of shell, wheels, etc?
02-08-2017, 07:39 AM
Some of the calculations seem like we're forgetting the roof. Not sure about area of windows and vents, but subtract it before you double for two coats.
Perimeter x height (sides).
Add length x width (roof).
Subtract total area of windows and vents (calculate in inches and divide by 144).
Then double.
Add 10-20% for waste.
02-08-2017, 11:20 AM
Deep South
No that is for the entire shell, I forgot to mention I used that number for insulation, and subtracted for wall covering above the benches.
