12-28-2014, 10:30 AM
Trailer: Scamp 16
Scamp Door Seal Glue Removal??
I'm about to change the open cell foam door seal on our Scamp to the new rib door seal. The original is falling off, but the two-sided tape or adhesive that held it on, sticks to the door frame. I'm wondering if anyone can recommend an effective solvent or remover to clean it off? I thought acetone might work, but was informed it can dissolve gelcoat Anyone use naphtha a.k.a. lighter fluid? Turpentine?
Our trailer is in storage so I can't try anything out very easily. I'll probably tackle the job at Scamp Camp in Sebring, FL in February. I know at least 3 others who may be doing the same thing.
Thanks in advance for any suggestions!
Tom
12-28-2014, 11:24 AM
WD 40 or Goof off work well in conjunction with a plastic scraper.
Dave & Paula
12-28-2014, 04:20 PM
Name: Norm and Ginny
Trailer: Scamp 16
Wd-40
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
12-28-2014, 04:23 PM
Trailer: Scamp 16
I have a small can of that in the camper tool box. Another use for a fantastic product. Thanks!
Tom
12-28-2014, 08:16 PM
Trailer: Scamp 2017 16-ft SD / FB
glue removal
I use a product call Goof-Off. Its great but be careful. Read instructions
Henry
12-28-2014, 08:35 PM
Just stay away from metal scraping tools! Metal can score the gelcoat. I've lost a couple of thumbnails scrapping my Scamp... fortunately they grew back.
Best of luck!
12-28-2014, 09:21 PM
I used Goo Gone! You need to make sure you get the plastic strip off first and then let the foo gone soak in for awhile. I recently discovered that vinegar works really well at taking of sticky tags so it may be worth a try as well.
12-29-2014, 10:02 AM
Trailer: Scamp 16
Thanks. I'll pick up some Goo Gone or Goof Off as well. On Amazon the reviews are very similar, and they're both highly rated. I've been using lighter fluid all my life to remove sticker residue, but I'd rather be safe than sorry with our Scamp.
This is the "D" shaped seal that Scamp provided just prior to the new "Rib Seal" on the right. Either one is better than the open cell foam seal they were using, but the latest Rib Seal looks especially promising. Tom
12-29-2014, 10:54 AM
Trailer: Escape 21
Georgia
Tom
What site will you be in/on? I will come over and lend moral support. 😍 I want to change out our door seal on our Scamp 5er. We will be in/on site 2.
Michael
Sent from my LG-V410 using Fiberglass RV mobile app
12-29-2014, 11:24 AM
GOOD stuff there TomK! Love the new design and wish it had been around when I changed mine out! I'm glad Scamp finally decided to change it and if I understand correctly, they're putting it on ALL new Scamps out the door now??
The most trouble I had installing my door seal was the aggravating plastic strip left behind after removing the sponge. Maybe you guys at the Sebring "Seal-a-thon" will come up with some magic way to remove it. I left part of the strip on mine but after nearly 5 yrs, it's still holding.
Thanks for posting the pics!
12-29-2014, 11:30 AM
Trailer: Scamp 16
You're more than welcome Michael. We'll be in site 026. We are going to be there from the 8th to the 22nd of Feb. (2 weeks). Order a new seal, and I'll be happy to help you as well. I've never been in a 19. I'd like to check that out while we're at it.
Tom
12-29-2014, 11:40 AM
Trailer: Scamp 16
Darral, I'm told they are installing their new proprietary rib seals on new trailers now. It has to be a BIG improvement. Thanks for the encouraging words!
Tom
12-29-2014, 06:49 PM
Trailer: 2017 Scamp 16 Deluxe
Missouri
Just FYI -
The Scamp16L6 that Art picked up just the week before Christmas had the gray open-cell
foam seal on the door. 😢
12-29-2014, 08:42 PM
Trailer: Scamp 16
Originally Posted by rdickens
Just FYI -
Hi Ray, Art's must have been built before the new seals came in, I'm sure a phone call would take care of that. I've really had good luck with Scamp on warranty issues.
Tom
03-06-2016, 02:38 PM
Trailer: 2005 16 ft Scamp Side Dinette and 2005 Fleetwood (Coleman) Taos pop-up / 2004 Dodge Dakota QuadCab and 2008 Subaru Outback
Tom,
I'm just about to tackle putting my new seal in. Did any of the products you tried work better than the others?
Dave (and Marilyn who is now watching from above)
Sharpsburg, GA
04 Dodge Dakota V-8, 17 Dodge Durango V-6, 19 Ford Ranger 2.3 Ecoboost
radar1-scamping.blogspot.com
03-06-2016, 03:01 PM
Originally Posted by Radar1
Tom,
Use Brakleen on a rag, don't let it soak very long, then clean again with Isopropyl Alcohol.
The original gasket is attached with what is ostensibly double faced scotch tape. peel as much of that as possible before cleaning the surface.
Goo Gone might work well on the tape itself but it is likely to leave a mess which the Brakleen will make short work of.
03-06-2016, 07:57 PM
Thanks Floyd,
Got the old seal and tape off, letting it sit overnight since no rain forecast, then another wipe and dry with the alcohol before putting it on tomorrow.
Sharpsburg, GA
03-12-2016, 06:00 PM
Trailer: 16' Scamp
Wyoming
I used rubbing alcohol to remove foam tape adhesive, leaves no residue to affect new adhesive.
03-13-2016, 01:31 AM
MEK is available at Home Depot and will remove about anything. It is a commercial paint prep liquid.
Frank F
