Burro front window specs - Fiberglass RV
Old 06-23-2017, 12:52 PM   #1
Biasdr's Avatar
Trailer: Burro
Alaska
Howdy folks, I'd like to restore my 13' 1983 Burro front window so it will open. At present there are four half-sheets of plexiglass siliconed in place. I see it has 2 tracks and assume it was originally constructed like the door window.
Did it originally have a fixed screen? I assume it was half the size of the window. Can I make a screen frame with such a low profile?
Anyone have detailed pix or advice? As always, I appreciate FGRV.
Biasdr is offline   Reply With Quote
Old 06-23-2017, 01:15 PM   #2
likeair2me's Avatar
Trailer: SCAMP
Missouri
It would help if you could post some pictures of your current setup. It could be that the previous owner cobbled something together that is completely non-spec.
likeair2me is offline   Reply With Quote
Old 06-23-2017, 02:58 PM   #3
Biasdr's Avatar
Trailer: Burro
Alaska
Sorry. I knew I should've attached pix after I posted.
1st picture: right pane is nearer the inside.
2nd & 3rd: Pane on right is nearer the inside.
Old 06-24-2017, 11:48 AM   #4
Trailer: Burro
I have a 83 Burro and the window looks exactly like your pictures. There is a screen on the inside of the moveable plexiglass window. You see see the insert for the screen in your picture.
jgilardi is offline   Reply With Quote
Old 06-28-2017, 10:58 AM   #5
Biasdr's Avatar
Trailer: Burro
Alaska
Thanks so much for the reply. Do you mean the spot indicated in this attached picture? Also, does the screen remain fixed or does it too slide? Again, I appreciate it.
Old 07-02-2017, 06:10 PM   #6
Biasdr's Avatar
Trailer: Burro
Alaska
Anybody able to help?
Old 07-02-2017, 06:50 PM   #7
Trailer: Burro
Picture of 83 Burro Front Window
Hopefully this picture answers your question.
Facing forward, the left window is fixed in place. This right window slides. The window screen is only on the right side and it is fixed in place. So there are only 2 pieces of plexiglass (right and left).
Old 07-02-2017, 07:01 PM   #8
Biasdr's Avatar
Trailer: Burro
Alaska
Thanks Jim! I can't see a picture but think I get it. Looking forward I see a fixed left window. On right nearest me is a screen and behind that a window that slides left to be out of the way.
Now to figure how to build a screen for it!
Much appreciated.
burro
1992 Bigfoot Trailer Specs? Marianne B. Problem Solving | Owners Helping Owners 11 10-23-2017 03:30 AM
Burro Logo Specs Burro Bill General Chat 8 04-29-2016 11:13 AM
torque specs for aluminum wheels? Paul and Libby Smith Problem Solving | Owners Helping Owners 3 09-16-2009 11:21 PM
Need Burro Window Specs Kelly G Problem Solving | Owners Helping Owners 3 05-25-2009 05:59 AM
Lug Bolt Specs...1997 Scamp 13ft Deluxe Jeff G. Towing, Hitching, Axles and Running Gear 2 06-20-2006 11:15 PM
