Underside plumbing of 98 Burro - Fiberglass RV
Old 11-06-2015, 07:50 PM   #1
Trailer: Burro
Utah
I'm loving my new Burro and most everything is working like a charm. I bought it from a good friend and she's kept it in great shape.
I went to fill the water tank today tho and looked underneath and I'm pretty sure some plumbing is missing. Do I just need caps for the Grey and black water tanks, or is there more that's missing? I'd love to see a picture of what the underbelly of a Burro is supposed to look like. This is a 17 foot 1998.
Cynthia
Sent from my SAMSUNG-SM-N910A using Fiberglass RV mobile app
Cynthiablue is offline   Reply With Quote
Old 11-06-2015, 08:03 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
There is a lot missing - all the piping and valves that connect to a dump swivel. Must have had a tough life if they wound up using chains to hold the tanks up! As you're in Utah, you might want to give Konrad a call at Little House Customs - Arizona. Although he works mostly on Casitas, this would be simple for him if you can't find local help.
Home
Charlie Y
Old 11-06-2015, 08:41 PM   #3
Trailer: Burro
Utah
Thanks for the info. I'm in Idaho this weekend but I will call around next week to see what I can find. I may be going to Arizona next March.
Old 11-06-2015, 08:41 PM   #4
Trailer: Burro
Utah
Would it be possible that I lost the parts on the freeway?
Old 11-06-2015, 08:53 PM   #5
tractors1's Avatar
I doubt it - you'd still have pipe hanger brackets underneath. Most likely a prior owner was off-roading and broke the piping, then removed the brackets. There had to be some work done down there to clean up the holes on the tanks. If you look closely you will probably find evidence of saw cuts on the pipe stubs.
Charlie Y
Old 11-06-2015, 08:57 PM   #6
Trailer: Burro
Utah
Huh ok.
Old 11-07-2015, 10:36 AM   #7
bjdd44's Avatar
Trailer: Burro
Unfortunately I don't have any input for plumbing issue. But I did want to comment that, I have a '99 wide body burro 14' and I have chains holding my tanks too. So strange. I thought for sure a previous owner did that, but I guess not.
Good luck with the plumbing,
Brandy
bjdd44 is offline   Reply With Quote
Old 11-07-2015, 10:43 AM   #8
Carol H's Avatar
Cynthia most of what is missing is easily obtained & not hard to install. The dump valves can be found at any RV shop. You might want to start a new post with a title that asks someone to post a photo of the underside of their Burro so you have a good idea as to how it was all originally put together.
BTW seeing holding tanks held up by chains is a first for me! makes me wonder where the heck this trailer has been pulled.
Old 11-07-2015, 11:27 AM   #9
Trailer: '00 Burro 17' WB
Seattle, WA
My '00 Burro also has chains holding the tanks!
mglyons is offline   Reply With Quote
Old 11-07-2015, 11:50 AM   #10
Carol H's Avatar
Really? Was that how they were originally done?
Just goes to show never say never!
Old 11-07-2015, 11:59 AM   #11
bjdd44's Avatar
Trailer: Burro
I know chains right?! When I first saw it, I thought it was definitely something I was going to have to "fix". Now I am second guessing that.
Sorry Cynthia for changing the subject of the thread...
Brandy
Old 11-07-2015, 08:42 PM   #12
Trailer: Burro 99
Nevada
Burro
Cynthia
I have a 1999 Burro the tanks also have chains holding them in place. Looks like you will probably only need Dump Valves added and some fittings to make it easy to dump.
Thom
Thom is offline   Reply With Quote
Old 11-11-2015, 10:07 PM   #13
Trailer: 1998 burro 17'
my newly acquired 98 also has chains running under plastic tanks and am going to replace them with padded straps. i would have sworn that was a PO add on. look like trouble waiting to happen. already had a poorly supported fuel tank chafe through on my sailboat
george w is offline   Reply With Quote
Old 11-12-2015, 08:58 AM   #14
If you have a shop in your area that works on boat holding tanks, they might be a source for repair. Much similar systems in pleasure boats.
burro
plumbing plumbing plumbing..... Herb P Plumbing | Systems and Fixtures 6 06-17-2007 06:01 PM
Sealing/Repairing Underside of Floor Jeff G. Problem Solving | Owners Helping Owners 3 06-28-2006 02:17 PM
Water/Plumbing issues jefh Problem Solving | Owners Helping Owners 0 01-14-2006 12:18 PM
Bathroom Plumbing Leaks Legacy Posts Plumbing | Systems and Fixtures 4 06-20-2003 09:56 PM
Bigfoot plumbing vents Legacy Posts Plumbing | Systems and Fixtures 9 06-18-2003 09:13 AM
» Trailer Showcase
Yoda
dlux
Escape
Joni F
