7 pin connector on Casita water heater? - Fiberglass RV
Old 08-02-2015, 01:38 PM   #1
jon carpenter's Avatar
Trailer: 2013 Casita 17' SD
Illinois
The other day my wife and I were digging around the new to us, 2013 Casita SD, just checking where water lines, electrical wires, etc were run. No problems, just curious so if something would run afoul I would be a little more knowledgeable of what and where to investigate. When we lifted the seat panel at the rear dinette we found a seven pin connector on top of the hot water heater styrofoam with four wires run to it but nothing connected to it. Does any one have an idea what this is for? Systems testing, future something, something unplugged? Everything seems to work just fine, but I can't figure out for what this is used?
This is my first time trying to upload a photo, so I hope it comes thru. If it does, please excuse the bad lighting. Also, am not familiar with how to use the forum, so if this is posted in the incorrect location or if I need to be corrected how to use the forum, PLEASE let me know.
thanks...jon
jon carpenter is offline   Reply With Quote
Old 08-02-2015, 02:05 PM   #2
It's obvious that it goes to the James Bond dinette ejection system which you didn't get because you bought the SD instead of the Freedom. : )
Collin K is offline   Reply With Quote
casita
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Towing, Hitching, Axles and Running Gear 5 04-20-2008 02:11 PM
Yellow wire on 7 pin connector ? Mikeny Towing, Hitching, Axles and Running Gear 2 04-13-2008 01:22 PM
boler 7 pin connector troubles al gilliland Problem Solving | Owners Helping Owners 6 04-24-2007 01:02 PM
7 pin connector Dan Simon Problem Solving | Owners Helping Owners 2 08-05-2006 09:54 PM
Wiring 04 Highlander to 7 pin Bargman connector Gary Little Towing, Hitching, Axles and Running Gear 18 06-02-2006 07:46 PM
