Boler1300 fridge removal - Fiberglass RV
Old 03-31-2016, 03:16 PM   #1
Trailer: Escape 2017, 17B
I need some help to get my fridge out of my Boler. I have removed all the fasteners I can see or feel holding it in place, and it still won't budge. It's a 120v/12v and it says Domestic on the vent cover.
Christian in FL is offline   Reply With Quote
Old 04-01-2016, 05:39 AM   #2
Martins HeirCon's Avatar
Trailer: Trillium 1300
Georgia
Take the lower outside vent cover off and look for a screw or two into the floor. My old Dometic was mounted that way, and the new replacement fridge is the same way. ( i installed it per the manufacturer's instructions.)
Martins HeirCon is offline   Reply With Quote
Old 04-01-2016, 05:49 AM   #3
Georgia
http://www.dometic.com/QBankFiles3/E....036_17707.pdf
Name:	ImageUploadedByFiberglass RV1459511362.920478.jpg
Old 04-01-2016, 08:00 AM   #4
Thank you!
Sent from my C6530N using Fiberglass RV mobile app
Old 04-01-2016, 08:43 AM   #5
Keaner's Avatar
Trailer: 1973 13' Boler
There is also a metal band across the top of it. There should be 4-5 screws through the band into the top of the fridge housing. You'll have to remove the drawer to fully remove that band. Also, remove electric and propane and isolate it before you start.
Good luck!
Keaner is offline   Reply With Quote
Old 04-01-2016, 10:47 AM   #6
John in Michigan's Avatar
Trailer: 1979 Boler 1700
The Dometic fridge in my 1974 Boler 13 also has a steel hold down strap with threaded ends that go through the bottom of the trailer body. To remove the strap, you must remove two nuts attached to the threaded ends of the strap UNDER the trailer.
Old 04-01-2016, 10:50 AM   #7
Keaner's Avatar
Oh yes forgot about those. Mine were a rusted mess. A Dremel with cutting wheel makes quick work if them.
Old 04-01-2016, 01:14 PM   #8
Also, my 1974 Boler 13 Dometic fridge has a propane connection (you didn't mention). That has to be disconnected and probably pulled down through the bottom of the trailer. (Edit: Of course first the propane tank(s) must be shut off and disconnected.)
Old 04-03-2016, 04:30 PM   #9
Hi everyone, I got my fridge out today, after removing the six screws holding it in place. I had to get under the trailer to take them out. Thanks for all of your help.
Old 04-03-2016, 04:44 PM   #10
Keaner's Avatar
Where's the pics of your Boler?
Old 04-03-2016, 04:52 PM   #11
I wasn't able to post any. I tried from my phone and laptop.
boler, fridge
Scamp Fridge Removal Ideas summer scamp Modifications, Alterations and Updates 22 07-28-2016 05:39 PM
73 Boler fridge removal? Vernois Problem Solving | Owners Helping Owners 2 09-16-2013 10:38 AM
Fridge door seal - removal Scouter Dave Care and Feeding of Molded Fiberglass Trailers 7 05-07-2012 02:29 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Boler 13 kitchen base removal (with 3-way fridge). I'd love to hear any tips! Raya Care and Feeding of Molded Fiberglass Trailers 19 09-26-2010 07:58 PM
» Trailer Showcase
Our Pod
Bill&Ann
Purdy
Azurko
