I am the original owner of this extremely well cared for 1999
Scamp Deluxe. I call it 'Factory Custom' because we were able to arrange a few upgrades to be made to this unit at the factory at the time it was built that were not available from
Scamp. This trailer has been carefully maintained from new. The
fiberglass gel coat still has a nice gloss. This trailer is a joy to tow and so easy to set up and camp in. 1 7/8” ball coupler. I use a 7 pole round trailer connector. Unit is nice and dry and has never had any water
leaks. All new exterior snap caps installed in 2012.
I am located in Central Connecticut.
Some photos below, but you can also view an extensive photo album here
Scamp 13ft Deluxe Factory Custom For Sale by pedalmike | Photobucket
Factory Custom Upgrades
- GE 0.3 CU Ft Microwave Oven
- Fantastic Fan
- Leisure Components 3 Way Faucet (City Water/Electric Pump/ Hand Pump)
This 13’ Deluxe is very well equipped and has all of these features
- Convertible front sofa or twin bunkbed
- Larger rear bed (77” x 54”) that converts to a nice sized dinette
- Factory option Hehr crank-out jalousie windows – great for ventilation and can remain open in the rain
- Bifold Screen Door
- A&E Dometic 2500 Awning. Vinyl Awning Fabric in excellent shape
- Two custom Covercraft Weathershield HD breathable water resistant trailer covers – one older and one brand new in the box- WeatherShield HD Car Covers - Covercraft Car Covers. These sell for over $500 each. Covers have zippered door areas that lets you get into the trailer without removing the cover
- Carefree of Colorado Awning light that plus into porch light for power
- Three Way Dometic Refrigerator with small freezer – works perfectly
- Two Burner Suburban Propane stove- works perfectly
- Propane Furnace with thermostat – works perfectly
- Gray water tank with dump connection and sewer hose storage tube w/ hose
- Brand new larger Group 31 Deep Cycle battery
- Charge Wizard intelligent battery charge controller added to OEM Intelli-Power PD-9130 Converter
- Delta Roof Antenna and Park Cable TV hookup
- Newer 20lb. propane tank with 5/2014 manufacture date
- Goodyear Marathon Radial Tires manufactured in Canada – 5mm tread depth remaining
- All LED lighting inside and out except for side marker lights. 3 swivel interior reading lights. Includes Command Electronics large LED panel Stop/Tail lights. Form factor very close to original Scamp.
- Swing down rear leveling jacks – super easy setup
- Combo Smoke/CO detector
- Battery voltage gauge
- Clear and yellow porch light lenses
- Upgraded cabinet door pulls
