Originally Posted by rmartin057
Scamp 13- My battery was losing its charge (don't know why) and then on my trip home my tail lites (brakes, signal,lights) stopped working, are they connected. Does the battery actually power tail lites. Or does it sound like I have a short in my system.
If your TV is wired like mine??? The
Scamp Battery and TV battery are connected together through the wire that runs from the tow battery to the trailer battery. There should be a fuse in that wire near the TV battery.
But, your scamp's tail,stop and turn signal
lights are powered only from the TV's rear lamp wiring. And, it requires a ground wire circuit, not just a frame ground, as the
Scamp lamps are mounted on
fiberglass. A bad ground could be the cullprit./wc
