Yes it is important to break the gloss on PVC pipe before gluing. The fittings are very glossy. Before they
sold the purple primer we used MEK to etch the gloss. It takes about 30 seconds of swirling with a wet dauber brush to break down the shine. The pipe will clean faster due to a more porous surface.
Another hint is to apply cement to the socket first, and then do the spigot. The cement does not dry as fast inside the socket due to the concentrated fumes. This give you more time to work, which is critical on large sized pipe on warm days.
Work fast and push the pieces together until hitting bottom, and quickly give the part a quarter turn. If the part requires orientation, plan your quarter turn accordingly.
If done like above it will never leak, and won't
fall apart.
If assembling ABS Black pipe you omit the primer, as the cement has adequate solvent to etch the pipe. You have to be quick to get your quarter turn with this stuff as it goes off fast!
Russ
