Low pressure gas - Fiberglass RV
Old 03-05-2019, 04:11 PM   #1
Trailer: Bigfoot 25RQ
Mississippi
Low pressure gas
Our Bigfoot 25RQ has a low pressure propane outlet for cooking grills oct. My wife has a griddle that uses the one pound bottles for cooking. I purchased a hose that will allow us to connect the griddle to the low pressure outlet on our camper. Only problem is it won't work. I'm assuming the low pressure line won't flow through the regulator on the griddle. Any ideas on how to fix this?
snuffy2 is offline   Reply With Quote
Old 03-05-2019, 04:15 PM   #2
Glenn Baglo's Avatar
You have two regulators in line with that set up. You need to remove the one on the griddle and hook up the hose ( if that can be done ). Same issue with BBQs.
Old 03-05-2019, 04:43 PM   #3
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
The regulator on the griddle is most likely also the flow control. You will need to connect to a high pressure source the same way the little bottles are connected. You can purchase a hose to connect directly from a 20 pounder to the input on the griddle regulator from amazon.
Your heirs will inherit money and stuff when you are gone. You can only save or spend money, but you can do things with stuff, so they are going to inherit stuff!
CarlD is offline   Reply With Quote
Old 03-05-2019, 05:39 PM   #4
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
If it is a Blackstone Griddle, the flow control and the regulator are not the same assembly. There is an adapter available that can be connected to a low pressure hose. The quick connect outlet on the trailer is tapped off of the gas line after the regulator and is already supplying propane at 11 inches of water column. Therefore, using the griddle’s regulator would essentially block any flow. It requires full tank pressure to work, and at full tank pressure it would reduce flow to 11 inches of water column.
Old 03-10-2019, 08:33 AM   #5
Mississippi
Solution found
Found this website, they have kits/adapters for just about anything. Oderered the 12 foot hose with QD for coleman and Blackstone. The fittings are QD on each end. No worries now, with my luck the wife will decide to use electric now!
Just passing the info.
https://propanegear.com
https://propanegear.com/converta-bp-...tone-griddles/
https://propanegear.com/coleman-road...quick-connect/
Old 03-17-2019, 12:51 PM   #6
Borden's Avatar
Name: Borden and Carole
We have the Coleman adapter from their site that goes to our 5 lb tank works great.
Our postage stamp in heaven.
Borden is offline   Reply With Quote
Old 03-21-2019, 04:15 AM   #7
Trailer: BigFoot
Thanks for listing those sites for propane accessories. I may need them. I have a quick disconnect on my Big Foot to which I hope to connect my Blackstone griddle and my Camp Chef Ranger II Blind Stove. Although I have a number of hoses, I bet I will be forced to buy yet another from the sounds of it...
Old 03-21-2019, 04:54 AM   #8
C&G in FL's Avatar
Henry,
If you have a hose with a low pressure female fitting on the end and a fitting on the other end that plugs into your trailer, probably not. The adapter for the Blackstone Griddle (@ $25) simply replaces the assembly Blackstone supplies and it has a male low pressure fitting onto which you connect your hose. The Camp Chef Ranger II has (when I bought mine) a flare fitting. You need a low pressure male fitting (usually 1/4-inch NPT, that’s “pipe thread”) and the correct size flare to NPT adapter. The flare to NPT adapter is readily available at Lowe’s or Home Depot (Ace Hardware, if you want to spend twice as much for the same thing!). The low pressure male fitting you may have to find online or at a propane supplier. I would buy 2 or 3 male fittings just in case you want to hook up a grill or a propane fire pit at some point in the future.
Old 03-21-2019, 04:57 AM   #9
Trailer: BigFoot
Thanks you Carl
Old 03-23-2019, 04:26 PM   #10
Nevada
One pound bottles are NOT low pressure! These small bottles are basically the same pressure as you 20 lb tank, but smaller. The appliances (stoves, grills, heaters) have their own, built in regulars. You can use these appliances, but you will need to tap off you gas bottle UPSTREAM or the regulator. These fittings, hoses, “T’s”, etc. are readily available from most camping supply stores and can be identified by the same male/female fittings as are on the 1 lb bottles and their appliances. I used this setup for years with my pop-up to run my coleman stove outside and a catalyctic heater inside.
egfasdsdsz is offline   Reply With Quote
Old 03-23-2019, 07:43 PM   #11
C&G in FL's Avatar
I do not believe anyone who has posted to this thread has either stated or claimed that one pound bottles supplied propane at low pressure. Low pressure systems on RVs are merely connections which have already been regulated, allowing the user to plug in appliances that are designed to run on low pressure or have had their manufacturer supplied regulators removed allowing them to operate at the pressure their original regulator would have supplied. And I believe most of the people who are on the forum are aware that tank pressure is the same regardless of the size of the tank, unless, of course, if the tank is empty.
Old 03-23-2019, 09:41 PM   #12
Nevada
What I read in the original post was ”Our Bigfoot 25RQ has a low pressure propane outlet for cooking grills oct. My wife has a griddle that uses the one pound bottles for cooking. . .”, which sounded to me like this person did not know the difference. Only trying to help. Sorry to get your blood pressure up!
Old 03-23-2019, 10:20 PM   #13
Actually, the poster did know the difference and was looking for a solution.
Old 03-24-2019, 08:47 AM   #14
Nevada
If you had read my complete post you should have seen that I said these parts are “readily available at most camping supply stores. . .”.
Old 03-24-2019, 09:49 AM   #15
Trailer: Escape 21C
LPG
Our grille came w 1 lb fittings but I hate using the green bottles bks they seem such a waste. We bought a refillable 5 lb tank and 6' hose to fit the grille..all works fine. We do keep one green bottle as a spare in case that 5 lb tank runs dry on a long trip....not happened yet
Fred762 is offline   Reply With Quote
Old 03-24-2019, 02:03 PM   #16
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Some of these threads create low pressure gas!
Old 03-31-2019, 07:59 AM   #17
Mississippi
Parts arrived
Parts arrived and work as advertised if using one at a time such as the griddle or the stove but not both together, I can live with that. For those interested if you buy the 22" griddle from blackstone it comes with an adapter for propane bottles. I just didn't want to carry more stuff!
bigfoot
Low-pressure outdoor stove Al Bear Camp Cooking, Food & Recipes 10 06-27-2018 12:36 PM
Low cold water pressure xbassman Plumbing | Systems and Fixtures 4 07-07-2016 02:17 PM
Low Pressure Regulator jmacchi Problem Solving | Owners Helping Owners 5 01-23-2009 10:55 PM
Pinhole in Gas Pressure Regulator? Daisy Problem Solving | Owners Helping Owners 3 10-16-2006 09:01 AM
Gas mileage vs. tire pressure General Chat 0 01-01-1970 12:00 AM
