Scamp lights - Page 2 - Fiberglass RV
Old 01-02-2019, 07:33 PM   #21
Originally Posted by Janis Morley View Post
.. I'm open to anything else we might try. Thanks, Janis
I thought we covered that.
Trace and test the wiring. Esp the negative. 100 ways to do it. Here is one. Use your multi-meter to check for near zero resistance from the negative (ground) terminal on the trailer plug (to the TV) and any of the negative pins on the outside lights. High or infinite resistance indicates a failed connection on the negative (ground) side. Then through process of elimination, isolate it, then repair it. Do this with no battery and no shore power. In this case you are not looking for voltage but voltage can damage the meter on continuity (ohms) setting.
Old 01-03-2019, 02:17 PM   #22
Trailer: egg camper 13 ft
Many thanks for all your help with my lights not working on my Scamp...we got it fixed��!! It was the conversion box in the tow vehicle. I greatly appreciate all of your help!
Janis Morley is offline   Reply With Quote
Old 01-03-2019, 04:14 PM   #23
...Sadly, there's nothing wrong with our tow vehicle. It's something in the Scamp....
...we got it fixed��!! It was the conversion box in the tow vehicle...
Glad you got it fixed, -- we were sure confused.
Old 02-01-2019, 12:20 PM   #24
Trailer: 13' Scamp
Minnesota
This happened to me as well. The color codes for scamp do not match the 7pin. I would find the scamp electrical schematic,
usually the back page of the owners manual, and find the coding to the 7pin. On the scamp plug, match the wires on the plug to the 7pin. You will have to rewire the plug to match as you cannot change the 7pin. This worked for me. I have a 1998 13' Scamp.
ScamperFun is offline   Reply With Quote
light, lights, scamp
Tail lights, marker lights, reflectors jeroen Modifications, Alterations and Updates 15 10-30-2017 06:06 PM
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
