Axle change for new Scamp 13s - Fiberglass RV
Old 03-19-2019, 12:57 PM   #1
floyd's Avatar
True to their dedication to constant improvement, Scamp is now supplying new Scamp 13s with zero axles and 10" brakes!!!
This will result in a bit more needed ground clearance and better braking.
Old 03-19-2019, 05:18 PM   #2
Jon in AZ's Avatar
Old 03-22-2019, 07:52 PM   #3
Hi floyd,
We're picking up a new 13 in June. What's a zero axle, and what difference will it make for ground clearance?
Pdxrain is offline   Reply With Quote
Old 03-22-2019, 10:05 PM   #4
floyd's Avatar
Originally Posted by Pdxrain View Post
Hi floyd,
The Scamp13 has been using a 22° up axle angle which resulted in the trailer having low ground clearance and lower clearance for garage doors.
(The 7' clearance has been gone for decades anyway)
A 0° axle has a start angle of 0°.... the trailing arm start angle is level with the ground. The result is a little more ground clearance.
A pure guess is something around 3"+-
This is a good thing since so many Scamp13s now have water pumps and gray water tanks with their associated drains, etc under the trailer.
This means that you will have some more clearance for entering driveways, gas stations or campsites reducing the possibility of damage to the stuff under your trailer.
The difference will be a slight increase in the overall height of the trailer, but not so much as to require a step for entry.
The increase to 10" brakes is also an improvement since 10" brakes are more effective and as a bonus, cheaper to service.
Old 08-15-2019, 09:04 PM   #5
Idaho
Just to clarify...
Floyd, it's been a few years since I've been on this forum, but inevitably I need some more advice! Pretty sure I need to replace the original axle on my 1998 Scamp 13' because it no longer takes the bumps very well and appears to be riding lower than normal, are you saying a 0 degree would create enough clearance or is it still popular to purchase the 22 degree? Do you know the specific Dexter axle that would fit the '98 Scamp 13ft?
katidesc13 is offline   Reply With Quote
Old 08-15-2019, 10:05 PM   #6
floyd's Avatar
Scamp has now made the 2200 pound, 0° axle standard and it now has 10" brakes.
I just installed one on my 2004 Scamp13D.
Its just the right height for towing and stepping into. I am much more comfortable with the clearance for all the plumbing underneath.
My old axle was still good but I wanted the additional height and better brakes. It is also now a bolt-on. I'm happy with it.
In 1998 some Scamp 13s still had leading arm axles, check yours, then call Jerrod at Scamp.
Here is a photo of mine with the new axle installed...
( the other picture is the same trailer when brand new)
axle, scamp
Best (easiest?) way to lift a Scamp 5er - New axle vs Axle-Less Trailer Suspension dreschool Towing, Hitching, Axles and Running Gear 7 06-26-2015 04:28 PM
Change this change that jgraps1958 Modifications, Alterations and Updates 17 10-09-2014 08:23 AM
axle change h.mike Towing, Hitching, Axles and Running Gear 0 06-22-2011 09:37 AM
ANOTHER AXLE CHANGE D Tharp Towing, Hitching, Axles and Running Gear 3 07-16-2010 08:19 PM
Bigfoot 17' Axle Change Legacy Posts Modifications, Alterations and Updates 3 06-11-2003 01:02 PM
