Casita 17' SD bed modification - Fiberglass RV
Old 07-22-2017, 07:58 AM   #1
Trailer: 2014 Casita Spirit Deluxe
Looking for information on having a permanent bed in the back of our 17' Spirit Deluxe Casita. Possibly replacing table top for better support and a side rail.
LauraN is offline   Reply With Quote
Old 07-22-2017, 08:21 AM   #2
We bought a Southern Mattress for our SD 17 and really like it. I plan on replacing the table top with plywood, but went three months last winter with the table. Our side table is secured permanently in the up position.
Old 07-22-2017, 09:29 AM   #3
Trailer: (Former) Casita 17 SD
We full-time and keep back of the SD17 set up as a bed always. A few weeks ago, the table cracked. The post holders, I believe, make the center weak, as well as the fact MDF board not that sturdy. It's a problem many experience.
As a quick fix, I added a few PVC pipes as legs under the cracked board.
We have ordered a 1/2 inch finished hardwood sheet of wood to replace the broken one.
Elly G is offline   Reply With Quote
Old 07-22-2017, 10:03 AM   #4
I cut a piece of 1/2 inch plywood for bed. Works for me.
pholloway is offline   Reply With Quote
Old 07-22-2017, 10:46 AM   #5
Thank you for the suggestions.
Thank you for the suggestions. We were thinking about putting in 3/4 inch plywood (because we have some) and wanted to see if others did the same and what their experiences were with it. We would like to drill holes in it so that it can "breathe".
Old 07-22-2017, 11:04 AM   #6
If you're concerned about moisture under the mattress there is a product for that. Look up Hypervent Marine.
Old 07-22-2017, 11:35 AM   #7
DebCost's Avatar
Trailer: Casita SD-17
Chicago, Illinois
SD bed mod
I used 1x6 inch pieces of wood laid side be side with small gaps to allow air circulation under my Visco 8 inch Memory Foam Mattress. I also downsized to a twin mattress to give me more floor space and left a gap at the rear where the curve is to store extra rolled up blankets.
DebCost is offline   Reply With Quote
Old 07-22-2017, 12:43 PM   #8
Peer n Brandee KL's Avatar
Trailer: Casita 17 ft Spirit Deluxe
How much more does the 1/2 inch plywood weigh than the table (hardware removed from underneath table weight)?
Peer n Brandee KL is offline   Reply With Quote
Old 07-22-2017, 08:31 PM   #9
According to our calculations, the plywood is actually lighter (and stronger) than the mdf table (without hardware underneath).
Old 07-22-2017, 10:24 PM   #10
We have used the table between the seats as a base for our Sleep Number bed for 10 years now. No problems with table or anything.
Jann Todd is offline   Reply With Quote
Old 07-22-2017, 10:36 PM   #11
Bed
My LD has a permanent double bed installed. I got a eight inch foam bed with a zip on cover from Walmart. I used the cushion to get the correct radius so I could trim the mattress to fit the rear curved wall. I just marked it with a sharpie. And cut the foam with an electric bread knife, it cut like. Bread! Zipped the cover back on and it fit perfectly.
I have had it a year now and still love my bed....and it cost less than three hundred dollars.
Leej is offline   Reply With Quote
casita
Bigfoot gaucho bed modification Yvon Chayer Modifications, Alterations and Updates 32 06-27-2017 10:58 PM
Scamp 5er bed modification: How much skill is required? Mike Sullivan Modifications, Alterations and Updates 20 08-08-2013 01:31 AM
Looking for bunk bed/couch modification johnbowes Modifications, Alterations and Updates 1 04-22-2013 06:22 PM
Bigfoot B19 Dinette Bed Modification V'sGlassSleeper Problem Solving | Owners Helping Owners 1 04-16-2010 01:27 PM
Bigfoot B17 Bed Modification Maureen M. Modifications, Alterations and Updates 3 08-30-2007 04:00 PM
