Trillium 1300 1980 - Fiberglass RV
Old 11-25-2019, 05:58 PM   #1
JR MASTER's Avatar
Trailer: TRILLIUM
Trillium 1300 1980
Hi,
We just brought Trill home.Gonna need TLC in many ways,
Wanted to ask forum about our Trilliums suspension,It sags quite a bit on the right side. Leaf springs and axle look ok.
13 inch wheels seem small on this camper(lots of room in wheels wells) Would anyone suggest 14 inch rims?
Thx.
JR
PS,Looking for rear window
JR MASTER is offline   Reply With Quote
Old 11-26-2019, 08:49 AM   #2
TomA's Avatar
Trailer: Trillium Manufacturing
Are you sure you have a Trillium? None of them ever had a leaf spring axle.
If it's sagging, there can't be any clearance since there wouldn't be anything extra for 14" wheels to fit. You should post pics.
Tom
TomA is offline   Reply With Quote
Old 11-26-2019, 10:03 AM   #3
Trailer axle
Please can you post some pics of the trailer and said problem this would be great. Thanks
Old 11-26-2019, 02:16 PM   #4
JR MASTER's Avatar
Trailer: TRILLIUM
Hello,
Thank you so much for your response..
I have a lot of questions about our newly acquired Trillium.
I will post pics asap.( Parked at another location for now)
Thx.
Old 11-26-2019, 03:07 PM   #5
JR MASTER's Avatar
Trailer: TRILLIUM
I was able to get 2 pics in Gallery section.... Will get suspension pics soon.
Title sez 1980 trillium 1300. Lady we purchased it from said she we 2 owner since 1993 and PO installed longer rear bumper for box and AC in rear window. The ac unit in rear window was being held in with plywood 2x4 s ,30 tubes of silicon and caulk+foam,duct tape etc. It rains a lot in Florida and she was proud to show us it didn't leak inside and around AC. ( We would love to find whole used/ new rear window)
Interior is in great shape, Electric receptacles ,lamps work.2 burner gas stove,.PO installed microwave under sink and newer refridge. Cushions are all new foam and ok covers.
Wife is not impressed with this "old thing"...(after 32 yrs it's ok though)
My object is bring it back.
Thx ... in advance for any tips or comments on fixing her
Old 11-26-2019, 05:43 PM   #6
Should not have a leaf spring axle unless someone modified it. Original was the typical torsion axle you see on lots of small trailers.
Old 12-04-2019, 12:49 PM   #7
With a little modification you can put 14" aluminum Ford Ranger wheels on it, I've put them on over 20 Trillium's and they look and work great. There's what is called the Deer Foot and Bullet pattern's I've got a junk yard that sells them to me at the cost of scrap aluminum around $12 each.......
Old 12-04-2019, 07:51 PM   #8
JR MASTER's Avatar
Trailer: TRILLIUM
Great info,Thanks. We've only had ours for 2 weeks.looking forward to bringing it back. Those rims would be nice .Would you happen to know if there are any rear windows available anywhere? Previous owner basically destroyed one bank on right rear window to install ac unit.
JR Master
Old 12-04-2019, 09:48 PM   #9
Yes, several followed Randy's advice and went with Ford Ranger wheels. I picked up a set of four off C/L for $50. I did have to swap out the hub studs, they were too short.
Finding a window for a 40 year old RV? Not likely. Find a window shop that can repair the one you have would be my advice.
1977 Trillium Wheel Upgrade by wrk101, on Flickr
Old 12-05-2019, 07:15 AM   #10
JR MASTER's Avatar
Trailer: TRILLIUM
Hello and thank you for the advice.I've been to several window places,seems no-one is able to help,I'll keep searching.
Going to look for Ford Ranger wheels!
Thank you. JR
JR Master
Old 12-05-2019, 07:18 AM   #11
JR MASTER's Avatar
Trailer: TRILLIUM
Hello again.
Are the ford rims 14 inch?
Ty
JR Master
Old 12-05-2019, 11:30 AM   #12
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
get the measurements of the window, and search rv salvage, any oversize window can be made smaller. RV Dr George seems to have a large inventory
Joe
Old 12-05-2019, 10:12 PM   #13
Originally Posted by JR MASTER View Post
Hello again.
Ty
Yes
Old 12-06-2019, 12:09 PM   #14
JR MASTER's Avatar
Trailer: TRILLIUM
Thank you.
I did call Dr Geo. Rv Salvage. Sending them specs.
JR
JR Master
Old 12-06-2019, 12:49 PM   #15
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Tom
Is there a reason Torsion axles systems can't sag on one side?
Old 12-07-2019, 07:39 AM   #16
JR MASTER's Avatar
Trailer: TRILLIUM
Hello,
Of course after purchasing.I researched the 1980 Trillium more ,only to find out that our suspension has been modified with ( I think) larger axle with brake , leafsprings,double shackles ….Trailer leans to right side quite a bit.I have pics but having pc / apple phone xfer issue.
Thanks ..
JR Master
Old 12-07-2019, 12:16 PM   #17
Raspy's Avatar
Trailer: Roamer 1
Sounds like it is either heavy on one side, or has a weak spring. Leaf springs are easy to change.
Old 12-17-2019, 06:02 PM   #18
JR MASTER's Avatar
Trailer: TRILLIUM
Originally Posted by Randy Bishop View Post
With a little modification you can put 14" aluminum Ford Ranger wheels on it, I've put them on over 20 Trillium's and they look and work great. There's what is called the Deer Foot and Bullet pattern's I've got a junk yard that sells them to me at the cost of scrap [ATTACH]Attachment 132556ATTACH]aluminum around $12 each.......
Hello took your advice found 4 Ranger rims for 75$.
Came with bad tires and want to replace w/sST205/75/14 OR ST 205/80/14.
Do you know if they will fit these wide rims?
Thankshttp://www.fiberglassrv.com/forums/attachment.php?attachmentid=132556&stc=1&d=1576627 209
JR Master
Old 12-18-2019, 02:01 PM   #19
Tires I use on mine are Vanguard STR ST205/75R14, I find these brand new $40 each and bought 12, the guy sold me 12 for 37 each. Don't know where nghe got them he had several brand new tires of different sizes, I bought all the ones he had that fit....
Old 12-18-2019, 02:15 PM   #20
I did have to change the studs as the original ones were too short for the Ranger wheels. I don't remember the length I bought.
trillium
NFLD (Canada) - 1980 - Trillium 1300 Front Dinette - $4500 David Tilston Referrals: Molded Fiberglass Trailers 4 04-11-2016 03:21 PM
ON | SOLD: 1980 Trillium 1300 for sale in Ontario $5000 Tonydd Classified Archives 0 09-01-2013 12:17 PM
CANADA - 1980 - Trillium 1300 - Factory Front Dinette - $3500 David Tilston Referrals: Molded Fiberglass Trailers 2 09-15-2012 03:55 PM
