Boler license plate holder - Fiberglass RV
Old 06-30-2013, 06:59 PM   #1
Trailer: 1978 Boler 13'
Wondering if anyone can help me sort out a little wiring problem with the license plate holder on my Boler. The light for the license plate wasn't working when we bought the trailer, I'd like to get it working again, thought it was just a burnt out bulb but seems to be a wiring issue, and I know very little about wiring.
If you look at the attached photo, the one wire that runs out of the trailer to the holder is taped to another wire inside the trailer, that wire has a connector on the end of it, but is not attached to anything. I'm assuming this unattached wire is the ground, but not sure where it should be grounded to. Realize this is probably a very basic question, but like I said, I know beans about wiring and hoping someone can help. Thanks.
desy is offline   Reply With Quote
Old 06-30-2013, 08:54 PM   #2
Kenny Strong's Avatar
Utah
I have different lengths of wire, with a clip on the ends. the wire with clips on it's ends, I would attach to the connector, and look for a ground source, to touch to or attach the other end to, I think you are right to think the second wire is the ground. If power is on to the running lights, and it can be determined where other items ground to, ie. metal surfaces or a bolt to the frame, or look for white or green wires and what they are attached to. Is the first wire hooked into another wire? There should be a couple of wires under the license plate light, going to the stop, tail light as you look into the compartment, the tail light is on the corner with wires coming out going down to the floor, it will have a ground wire you can attach to.
hope this can help
P.S. you should get a test kit to check hot and cold wires
Later kenny
Kenny Strong is offline   Reply With Quote
Old 06-30-2013, 10:41 PM   #3
I didn't really follow all of your reply, realizing that my original post may not be that easy to follow though. It looks to me as though there are two wires that are intended to go to the license plate light. One of them comes through the wall of the trailer to the license plate holder, and is screwed down on the holder, along with the thin metal plate that sits up against the back of the light bulb. You can see that wire in my original photo.
The other wire doesn't come through the wall of the trailer to the holder (maybe it did originally?). That wire has a connector on the end of it, similar to the picture that I'm attaching to this post. I'm thinking this connector needs to attach to the license plate holder in some way in order for it to be grounded, but can't see a place for it to attach.
I'm basing my assumption on the way that my side marker lights are wired. On these, there are two wires coming to the marker light, a green and a white (same as the license plate holder I think). Hope this all makes sense.
Old 07-01-2013, 05:01 AM   #4
Don, I hope this document in the Document Center will help you. It's for a Scamp, but wiring is wiring: Fiberglass RV - Document Center - WiringDiagram_Scamp
Best of luck!
Old 07-01-2013, 06:26 AM   #5
The wire(white?) w/terminal on the inside the trailer needs to supply the ground to the fixture. It should be attached to the fixture mounting bolt on the inside the trailer. You need to verify the function of the wires first. White (inside ground) black 12VDC hot.
Eddie
Old 07-01-2013, 07:04 AM   #6
GMike A's Avatar
Trailer: 2001 Spirit Deluxe 17" K5NAN
Once you buy one of those 2 dollar testers you will be able to see where the issue is. Wont hurt to lightly burnish the rust dot of the inside bottom tab with an eraser or something abrasive.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
GMike A is offline   Reply With Quote
Old 07-01-2013, 04:48 PM   #7
Thanks for everyone's input, looks like I got it sorted. A lot of my confusion I guess was due to the fact that the ground had not seemed connected to the fixture to begin with, although I guess maybe it just got disconnected somewhere along the line. Found a way to get the ground connected again, and it's working.
Old 10-08-2019, 07:05 AM   #8
Hi, old post I know. Just looking for another pic of that plate frame. I think my boler had the same one. Thanks
905Shelby is offline   Reply With Quote
boler, license
New License Plate Frame toledo2tokyo Modifications, Alterations and Updates 4 09-12-2012 08:35 PM
Installing a Backup Camera on the TV License Plate Kevin A Problem Solving | Owners Helping Owners 8 12-28-2009 08:07 PM
Smaller license plate shane n Modifications, Alterations and Updates 2 08-01-2009 07:48 PM
Putting a new license plate on a Scamp Monica M General Chat 6 05-27-2009 10:28 AM
Casita License plate costs Keith Williams Problem Solving | Owners Helping Owners 19 04-27-2009 06:30 PM
