Replacement vent cover for boler furnace - Fiberglass RV
Old 03-23-2019, 03:24 PM   #1
Yukon
Hi Everyone,
The exhaust for our boler's furnace (the original drip furnace) fell off before we bought it, and now that summer is coming i'm trying to get it fixed back up. Another generous forum member sent me a replacement exhaust, but I still need a vent for the outside. It seems like finding a part that fits should be reasonably straightforward, so wonder if anyone knows of a good option that's easy to order?
Thanks so much!
Chris
McRider is offline   Reply With Quote
Old 03-23-2019, 04:58 PM   #2
Byron Kinnaman's Avatar
This shouldn't be difficult. First look at the furnace and see if you find a manufacturer and model number. Then armed with that information go to manufacturer's web site and see if you can find an instillation manual. Look up the part number in the manual then call the manufacturer and tell them what you want by part number.
Good luck.
Old 03-23-2019, 05:36 PM   #3
Yukon
Unfortunately it's a bit more difficult than that, because it's the original Suburban furnace and they're no longer manufactured. As for the vent cover itself, the outside dimensions seem to be a bit unusual so I'm not quite sure what would fit.
I've seen someone share a suggestion on here before, but despite trying every relevant search I can think of, I can't find it.
Old 03-23-2019, 05:48 PM   #4
Yukon
Actually, i had a brainwave and found what I was looking for. This is the part that was suggested (though it's designed for indoor use):
https://www.amazon.ca/Imperial-RG056.../dp/B01N9V63XM
Though then I found this other option that might actually work well:
https://www.vintagetrailersupply.com...-p/vts-934.htm
It's a bit bigger, than the hole but I don't see why that would cause an issue?
Old 03-24-2019, 10:45 AM   #5
Trailer: !977 KingsleyGMC, 1968 Bailey Mikado
Nova Scotia
Instead of vintage trailer, you can get the same thing at a building supplier in the venting area...or you can in Canada.. And for less money in case McRider is Scottish! lol
panhead_mike is offline   Reply With Quote
Old 03-24-2019, 01:09 PM   #6
Suburbam firmaces has not gone out of business. Try https://www.airxcel.com/suburban/products/furnaces
Old 03-24-2019, 08:33 PM   #7
Roy in TO's Avatar
Looks like what I used on mine. I'm sure I posted the model number here somewhere. Might have been a special order through Home Hardware.
On edit, I looked at the one from Vintage Trailer in you post. That one has a lot less vent holes. I would not use it on a furnace exhaust.
Old 04-02-2019, 12:32 PM   #8
Yukon
That's not a coincidence Roy! I found the thread where you spoke about using it! I wonder how it's held up for you, given that it wasn't designed for outdoor use?
Old 04-02-2019, 12:41 PM   #9
Yukon
I wonder if this one would be suitable as well? It looks quite good: https://www.amazon.ca/Steel-Return-A...&sr=8-34-spell
Old 04-06-2019, 10:50 AM   #10
Trailer: boler
Hi Everyone,
Thanks so much!
Chris
I too have the old suburban furnace and the gas valve quit. i have been looking at all sources for a replacement , with no luck. anyone have suggestions?
gary car is offline   Reply With Quote
Old 04-06-2019, 10:51 AM   #11
Trailer: boler
Old 04-06-2019, 09:12 PM   #12
Trailer: boler
Old 09-17-2019, 08:41 PM   #13
Read this one
http://www.fiberglassrv.com/forums/f...ase-37948.html
go toward the end, Rick used a new controller, only left the inside: Burner and pilot. Even by his picture a new burner and pilot could be made by someone that has a Shop
Darlan is offline   Reply With Quote
boler, furnace
how to remove hydro flame furnace vent cover Tyhee Problem Solving | Owners Helping Owners 6 09-15-2016 07:57 AM
Boler Range Vent Cover Replacement? Eggbert Modifications, Alterations and Updates 0 09-01-2016 09:32 PM
source to replace exterior furnace vent cover Daryl and Wendy Problem Solving | Owners Helping Owners 10 11-28-2012 02:33 PM
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
Furnace vent cover Holly G Problem Solving | Owners Helping Owners 2 03-09-2009 09:04 AM
