qestions on 1973 boler rebuild, looking for windows - Fiberglass RV
Old 11-07-2019, 07:56 PM   #1
Trailer: 1973 Boler
Canada
I have a 73 boler that was laid over on its driver side the aluminum trim channel around middle of trailer covering the seam is all but gone has any one completely ground off the top and bottom flanges and fibreglass the outside the same as they did at the factory on the inside? failing this fix anyone have a suggestion for something to cover up original seam that was covered by aluminum c channel?
also looking for driver side jelousie windows small one over stove and larger one at back to left of sink
also wondering if anyone has removed closet and then reinstalled , and what method you used to reattach as side by door openning on mine has been stpled together?
thanks Bill
Bill B Estevan is offline   Reply With Quote
Old 11-08-2019, 10:41 AM   #2
Trailer: Trillium 13. boler 13.
thanks Bill
I have done all the things you are asking about.
Don't know your skill level, but not difficult.
I had to cut my shell completely in half during the rebuild; because there was so much damage Fiber-glassed the two halves together again. ( I did reuse the belly band).
I removed the ensonite and ground any residue off that was close to the joint. It (the ensonite) was relatively easy to reinstall.
Closet was reinstalled with stainless bolts through the shell. As were all the interior pieces.
Everthing was sealed with Butyl as I went along.
Hope this helps.
Martin.P is offline   Reply With Quote
Old 11-08-2019, 11:50 PM   #3
Trailer: 1973 Boler
Canada
i have the tools skill and ability as i worked in a fiberglass plant years ago just not sure if belly band flanges actually serve any structural function or if they were just left on from the moulding process at factory and covered up with the C- chanel trim. thinking about removing them adding a layer of matt and feathering it out with bondo to make a smooth wall.
ive already body worked most of the driverside now anyway.
Old 11-09-2019, 12:20 AM   #4
I think the belly band helps to keep the shell from spreading in the middle. Over the years, they tend to sink and spread.
M.
Old 11-09-2019, 12:55 AM   #5
Glenn Baglo's Avatar
M.
Escape trailers top and bottom are fibreglassed together while still in the mould. The belly band does nothing other than cover the seam for cosmetic purposes.
Old 11-09-2019, 07:29 AM   #6
Jon in AZ's Avatar
On a a Boler, aluminum trim on the belly band is cosmetic only. The interior cabinetry provides structural support for the shell. The closet by the door is especially critical.
You should be able to obtain replacement aluminum C-channel from a number of sources. Cutting off the lip and eliminating the seam altogether is also an option, assuming you’re going to paint the exterior after you’ve finished repairs.
Old 11-10-2019, 12:58 PM   #7
Trailer: 1973 Boler
Canada
if I can't find some replacement c- channel i will consider doing away with the moulding flanges altogether I know I can do the work and I have to re-coat the whole trailer anyway top and bottom so the removal and body work involved in removing the moulding flanges doesn't bother me,I had hoped to hear from someone that might have done it before.
I am assuming the C-Cannel is press formed and normal channel is going to kink if i try to bend it around the corners.any one have suggestions to totally replace it?
Old 04-05-2024, 08:02 AM   #8
Trailer: 1973 Boler
Canada
UPDATE
Some pics from the process so far. new gelcoat, belly band replaced with automotive u-trim, new radiused windows on sides new acrylic windows front and back. removed cooler fridge redesigned that area for storage with a shelf, new breaker panel(Scamp Parts) three new 120v circuit's, all new 12v LED lights, removed water tank disinfected replumbed all new tubing, new wheels and tires, new wood cupboard doors and covers on seat bench's, new laminate flooring, new primer and interior paint, new foam and upholstery, tons of body work as it had been drug down highway on the drivers side before i got it. new C-channel welded onto frame for strength, new roof vent with 12volt fan
left to do counter top with extension over the the sofa.
contemplating removing stove top and going with a portable two burner Coleman for more counter space
boler, windows
1973 boler complete rebuild robeye Modifications, Alterations and Updates 35 11-20-2018 01:56 PM
Rob's 1973 Love Bug Rebuild rkbn Modifications, Alterations and Updates 35 11-14-2018 02:02 PM
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
1973 amerigo gut and rebuild Kai in Seattle Modifications, Alterations and Updates 14 12-12-2015 03:39 PM
Bigfoot 15B17CB qestions Tony Nowak Problem Solving | Owners Helping Owners 7 09-27-2007 01:56 PM
