76 Trillium 1300 Reno - Fiberglass RV
Old 08-26-2014, 02:26 PM   #1
Trailer: 1976 Trillium 1300
Nova Scotia
It looks like a reno project may be in store. First question is does the belly band serve a structural function holding the upper and lower shell halves together? Then can someone point me to a thread about preparing for a trip to a fiberglass shop for cleanup and re finishing? (I don't have the skills set to take it on myself)
Seagull42 is offline   Reply With Quote
Old 09-02-2014, 10:45 AM   #2
David Tilston's Avatar
The belly band itself serves no function after construction. It is used to line up the top and bottom half of the shell. Metal plates on the inside of the shell and the belly band on the outside. They riveted the plates and the band together. This pulled the top and bottom so that they lined up. Then they ran a fibreglass bandage over the inside. This covered the metal plates and sealed up the seam. From the outside it looks like the metal plates are in upper and lower pockets. The problem is that the lower pockets that the metal plates sit in, fill up with water, (condensation?). In colder climates, this water freezes and slowly opens this pocket up, till it ruptures into the inside of the trailer. Now there is a leak in the belly band.
If all you are doing is putting the belly band back on, then no prep is required. The metal plates rust and fail to hold the band on anymore. They will probably put new metal plates, (washers?) in. so that a new rivet can be used to hold the belly band on. I have not tried this, but I suspect it is not easy.
If your trailer has been exposed to a constant freeze / thaw cycle, all it's life, then leaks may be a problem. There are several possible fixes. On the more extreme end is what I do:
http://www.fiberglassrv.com/forums/f...ead-58763.html
http://www.fiberglassrv.com/forums/f...ead-59580.html
Others have just filled the gap with bondo, and reinstalled the belly band. I personally like the way that Trilliums look without the band.
trillium
CANADA - Trillium 1300 - $1300 David Tilston Referrals: Molded Fiberglass Trailers 2 01-26-2016 01:34 PM
'Reno' of DuoTherm furnace in 1973 Trillium 1300 Young Blue Modifications, Alterations and Updates 9 07-05-2015 01:23 PM
fools rush in........1971 boler 1300 reno flatlander Modifications, Alterations and Updates 62 03-30-2013 06:42 PM
Starting a reno of a 1975 Trilliim 1300 mefilipo Modifications, Alterations and Updates 4 07-26-2012 02:17 PM
Trillium Reno Trillium.Stella Modifications, Alterations and Updates 6 04-26-2012 02:06 AM
