04-04-2014, 10:34 AM
Trailer: ParkLiner
Virginia
Parkliner Propane Refrigerator Question
I am just getting around to trying my propane appliances and I have a question. The Parkliner has a Dometic 3 way refrigerator. I can't tell if the gas is lit or not.
Instructions:
- Make sure gas is on
- Make sure electrical switches are off
- Turn thermostat control knob to high
- Depress thermostat control knob and hold down while pressing igniter several times.
- Keep knob depressed for another 10-15 seconds
- Release knob and check for flame through the opening in the metal burner cover
What is the metal burner cover? Is it the pear shaped metal piece that swings over the hole in the burner box? The manual refers to that as the opening in the burner box, not the opening in the metal burner cover. Are they the same thing?
It sounds like the gas is on and lit, but I can't see a flame.
04-04-2014, 10:58 AM
Yes, that pear-shaped flap is PIA device that allows you to peek in there to see if the pilot is lit. The sparker lights the pilot in that cube shaped box. The vertical tubular aluminum column over it is a chimney type thingy (tech talk ) and it gets warm to the touch pretty quick if the pilot is lit.
Ummm. I wouldn't put my eye too close to the opening
04-04-2014, 11:39 AM
Trailer: Trillium 2010
The flame is smaller than you'd expect and can be difficult to see especially in bright light. I find myself blocking the light around the hole and moving back and forth to find the correct angle. Sometimes, if it's quiet, I can hear the gas burning. Raz
04-04-2014, 12:03 PM
Trailer: ParkLiner
Virginia
I lit it and waited about 5 minutes to see if the burner box got warm - and it did. Then I put a thermometer in the refrigerator and it did show it was getting cooler.
Originally Posted by P. Raz
The flame is smaller than you'd expect and can be difficult to see especially in bright light. I find myself blocking the light around the hole and moving back and forth to find the correct angle. Sometimes, if it's quiet, I can hear the gas. Raz
I tried blocking the light and still couldn't see a flame. I even used a mirror to get a better angle and still couldn't see it. I'm not comfortable not being able to see the flame.
04-04-2014, 12:20 PM
I can’t say I’ve ever seen the pilot light when it’s daylight out. And I agree it’s vaguely uncomfortable not seeing it whenever you decide to look. I had to put it in the “home refrigerator light” category. I take it on faith that the light goes out when I close the door…
04-04-2014, 12:32 PM
Trailer: 2018 Casita SD - Kondo A-Go-Go
Utah
I got frustrated with not being able to see the pilot light and now just use either 110, if it is available or 12v. Thought about carrying a used paper towel or toilet paper tube and use it to block out the light looking thru it. But decided not using the propane was an easier solution.
Alice
KONDO A-GO-GO - I GO WHERE I'M TOWED
04-04-2014, 12:54 PM
The good news is if you can't see it its probable burning pretty clean Agree with the others though that if the stack is getting warm its burning and the only way to see it on a sunny day is to totally block out the light - often have to have someone stand right behind me at the right angle in order to block it out enough. If I couldn't see it at all that would worry me as well as mine is older it can be a pain to light up if not been used for a long time - often have to keep the button pushed down longer than I should in order to keep it light - other wise it will go out on its own.
Have you tried turning the temp of the fridge down as low as it will go - that should increase the flame level a little bit at first so you can better see it - on mine there are two separate temp controls one for gas and one for electrical.
04-04-2014, 12:56 PM
Trailer: 2000 Burro 17 ft / 2001 Toyota Tundra V8 2wd
On my Dometic gas fridge, there's a little gauge at the top front of the fridge, with a needle that swings to the right as it gets heated up by the flame. As long as the line is in the green area I know the flame is on. I'm assuming the gauge is powered by the thermocouple. I though all gas fridges had this.
04-04-2014, 01:58 PM
That is seriously cool! I'll have to spend a little time with the Lehman's catalog looking for a small stove thermometer.
04-04-2014, 02:13 PM
On my Dometic gas fridge, there's a little gauge at the top front of the fridge, with a needle that swings to the right as it gets heated up by the flame. .
Gezzz wish that was on all the Dometic fridges... I have actually never seen that or at least not noticed it on other fridges Or perhaps its on newer fridges? Which model do you have?
04-04-2014, 02:30 PM
Quite correct. The voltage level is quite small, less than 50 mV. If your fridge requires DC then there is an amplifier between the thermocouple and the meter. In most cases that same thermocouple keeps the safety valve open. The amp makes sure the meter doesn't effect the safety valve operation. I've never done it but with a high impedance voltmeter, which most digital meters are, you could probably measure the thermal couple voltage at the safety valve.
Norcold had a fridge with a meter and no amplifier. No DC connection. It didn't work well. The fridge would stop working at any time. Not good. Raz
04-04-2014, 03:23 PM
I forget the model number. It's original with the trailer which is a 2000 model year, so it's at least that old. I'll post a pic this weekend if I can remember. I actually have the reverse problem of the original poster, I can tell from that gauge it is lit, but looking at the back of the fridge, I see absolutely no access port, such that if I had to light it manually, vs. using the sparker at the fridge controls, I wouldn't be able to.
04-04-2014, 03:40 PM
Trailer: 1991 17 ft Horizon
Huck, I've always told people to lite the fridge at night, then you can see the little flame good. Must be the new Parkliner's switched to Dometic as the older ones are Norcold. And I can't remember if the Dometic's have a shut-off near the gas valve like Norcold does, so you might want to look for that too.
04-04-2014, 04:56 PM
New Jersey
[QUOTE=Wallo;450356]
What I usually do is take a BBQ lighter
light the lighter then blow it out while holding the gas button in quickly stick it into the viewing hole and pull it out to see if the lighter has a flame. Let's me know right away if its working.
deryk
04-04-2014, 11:53 PM
Hi Huck, after you light it a couple times it will be second nature to you if it cooling down or not. Haven't seen anyone else tell you but if your RV has been sitting for a while the propane kind of gets an air bubble in the lines. I nornally light the stove first to bleed the line as the stove uses more PL faster than the refer. Once the stove lights off, shut it down and then light the refer. I've had a number of RV's in 30 years with both Domectic and Norcold refers. Some had an indicator at the refer that showed the burner was lit and some didn't. I never had a problem knowing if they didn't light off even with the ones that didn't have an inside indicator. I could hear it burning or feel the heat after opening the outside access panel. In all the years I've only had two problems with my refers working. One thurmo coupler quit and kept it from lighting and another one while trying to light it gave off the "dreaded" ammonia smell......dead and a $1000.00 fix meaning a new unit but it was 15 years old.
I do two things now. I carry an extra thurmo coupler, quick fix and cheap and I keep a thermomitor in the box to keep tabs on the temp.
Beside a spyder making a web in the burner area (water heater too) they are pretty much bullet proof.
04-04-2014, 11:56 PM
Ditto on lighting the propane stove to get propane moving through the lines.
It works.
04-05-2014, 09:59 AM
It works.
I do the same, as well as before trying to light the hot water tank or run the furnace.
04-06-2014, 05:03 PM
Trailer: Parkliner #40 something
Last year when I plugged the Parkliner into the house electricity the battery got a little hot after a few hours. Do I need some kind of limiter or adapter when doing this? (Have been asking since January for a battery tray to be shipped. I hope that we can get one.)
Thanks for the help!
04-06-2014, 05:39 PM
if the battery is getting hot if only plugged in for a few hours, that sounds to me like it is being overcharged or gone bad. Does your controller have any settings on it that might change the way it charges or to reflect the type of battery it can charge.
Perhaps if you say what type/brand of battery you have and the make and model of your controller hopefully someone will have a better answer for you.
Edit to add: I would disconnect the battery and let it sit overnight and then take a new reading on it. If its not still fully charged then thats a real good indicator your in need of a new battery.
04-06-2014, 07:20 PM
New Jersey
Contact Chandler...
I know they prefer doing the battery upgrade in their shop because there is some custom fitting of the new battery box...but they will have to ship it to a fiberglass place since your kinda far lol. I was glad I did the 1000 mile round trip got some upgrades and stuff and was nice seeing the factory where my #003 was born!
deryk
