New member with a Boler! - Fiberglass RV
Old 08-30-2018, 02:23 PM   #1
Ontarioboler's Avatar
Hello my name is John!
In July I bought myself a boler. My plan is to live in it full time for 3-4 month in summer 2019 and travel along the west coast.
I have done a lot of work so far and am not quite done yet.
-removed frame, local trailer shop welded me some reinforcements that I thought could use some strength.
-wire wheeled the whole thing clean and painted with some black rust paint.
-on the boler itself I had to fix some fiberglass underneath. Grind down some soft areas that were holding in the wood floor. Get ride of all the soft areas and then added new fiberglass.
-installed new hubs and bearings
-new rims from vintage trailer supply with a half inch positive offset. I tried using canadian tire rims. They had 0 offset and they pushed the tire within a 1/4" of the fender. So I had to return them and get the new ones.
-tires I got were from tdot performance maxxis m8008, st175/80r.
-had a very fun time putting the egg back in the frame.
-the 2 side windows I removed, cleaned them up with steel wool and some aluminum buffing compound.
-got new glass cut for one of the windows which was cracked.
-reinstalled with fresh butal tape.
-front and rear windows I got ride of old seals and reinstalled with new seals from scamp.com
-installed a fantastic roof vent which I bought from Amazon. Made a wood frame for inlet in the inside and used 8/32 hardware to hold it in real tight. Butyl tape, then caulking.
-removed everything from the interior.
-clean clean clean cleaned the inside. Spent a few days scrubbing the interior walls and all the fiberglass to get it fresh again.
-cleaned up fridge which still works. Installed a new oat ply in the door to give it a fresh look. Reinstalled
-new cabinet doors all made from pine with a beeswax seal product.
-new counter top bought from home depot cut to fit
-new sink faucet
-new stove installed from atwood (amazon)
-build a fulltime bed set up with access door. Will be making drawers for the inside of the bed storage soon.
Can anyone date my boler? Beside the door it says boler Voyager. I don't have a vin number for it but I do had a very old sticker on the outside of it. Numbers were carved in by hand. Will be adding photos soon!
Lots of more work to go! But I am getting there.
Ontarioboler is offline   Reply With Quote
Old 08-30-2018, 02:44 PM   #2
Trailer: Sold it
Northern VA
Welcome
Progress pictures would be nice. Looks like a lot of work went into it.
Old 08-30-2018, 06:57 PM   #3
Here are some pictures from the day I bought it and progress along the way!Click image for larger version
ID:	124059Click image for larger version
ID:	124060Click image for larger version
ID:	124061Click image for larger version
ID:	124062Click image for larger version
ID:	124063Click image for larger version
ID:	124064Click image for larger version
ID:	124065Click image for larger version
ID:	124066Click image for larger version
ID:	124067Click image for larger version
ID:	124068Click image for larger version
Old 08-30-2018, 07:02 PM   #4
Here are some pictures of my progressClick image for larger version
ID:	124070Click image for larger version
ID:	124071Click image for larger version
ID:	124072Click image for larger version
ID:	124073Click image for larger version
ID:	124074Click image for larger version
ID:	124075Click image for larger version
ID:	124076Click image for larger version
ID:	124077Click image for larger version
ID:	124078Click image for larger version
ID:	124079Click image for larger version
Old 08-30-2018, 07:06 PM   #5
Progress picturesClick image for larger version
ID:	124081Click image for larger version
ID:	124082Click image for larger version
ID:	124083Click image for larger version
ID:	124084Click image for larger version
ID:	124085Click image for larger version
ID:	124086Click image for larger version
ID:	124087Click image for larger version
ID:	124088Click image for larger version
ID:	124089Click image for larger version
ID:	124090Click image for larger version
Old 08-30-2018, 07:08 PM   #6
ID:	124092Click image for larger version
ID:	124093Click image for larger version
ID:	124094Click image for larger version
ID:	124095Click image for larger version
ID:	124096Click image for larger version
Old 08-30-2018, 07:21 PM   #7
Trailer: Boler Deluxe
Wow, lots of work! Impressive. Look forward to pics.
lisapappas is offline   Reply With Quote
Old 08-30-2018, 07:32 PM   #8
In July I bought myself a boler. ...
-removed frame,..
-wire wheeled the whole thing ..
-...fix some fiberglass underneath. ... and then added new fiberglass.
-new rims ....
-tires ...
-.. 2 side windows I removed...
-got new glass ...
-.. got ride of old seals and reinstalled ....
-installed a fantastic roof vent ..
-clean clean clean ...
-cleaned up fridge .... Reinstalled
-new cabinet doors ...
-new counter top ...
-new sink faucet
-new stove ...
-build a fulltime bed set up with access door. ...
Most of the time the first post made by a forum member is a simple question. And often one that has been asked many times before.
But not this guy.
Wow, what a great project and what skill you have. welcome.
Old 08-30-2018, 07:32 PM   #9
Trailer: Sold it
Northern VA
Looked good to begin with, I think. Nice work throughout.
Old 08-30-2018, 07:46 PM   #10
Glenn Baglo's Avatar
Yup. It's usually, "I've gutted my trailer; what do I do now"?
Old 08-30-2018, 09:05 PM   #11
rbryan's Avatar
Arkansas
Wow, you've been busy! Nice work on the interior.
Old 08-31-2018, 07:26 AM   #12
Thank you for the support! Haha I like that comment. I know it might not have needed everything I did. I like doing things all or nothing though. I did use the forum a lot for reference on some topics!
Old 08-31-2018, 10:22 AM   #13
Trailer: Trillium 1979 13ft.
Boler reno
Wow, and more WOW! This blows my mind! So much work in a short space of time. You rock, mister!
Butsky is offline   Reply With Quote
Old 08-31-2018, 10:27 AM   #14
Thank you! 150 hours of my labor in 6 weeks
Old 08-31-2018, 10:50 AM   #15
bullfrogeh's Avatar
WOW !
VERY, VERY impressive work ! And, in such a short time. Welcome to the rest of the 250 'currently active' FGRV owners - in Ontario, many of which also do the Boler thing ! Hope to met you personally sometime; when you're not too busy ! (But, I wouldn't dare interfere with your obvious schedule.) Care to share your location area ? - 'Dave' in the 'Highlands'.
Find yourself; and then others will find you.
bullfrogeh is offline   Reply With Quote
Old 08-31-2018, 10:51 AM   #16
MurrayC's Avatar
Trailer: Ventura
British Columbia (BC)
John
You are doing a great job.
I rebuilt my 1976 new to me Ventura last winter and am looking at an old Boler which would need a full restore as you are doing.Great job. Pics are nice.
Keep us posted of your progress.
Go and Enjoy soon.
MurrayC is offline   Reply With Quote
Old 08-31-2018, 10:55 AM   #17
MurrayC's Avatar
Trailer: Ventura
interior
John
What did you finish the interior walls with? Did you insulate?
Old 09-01-2018, 07:48 AM   #18
Originally Posted by MurrayC View Post
John
Hey Murray! Thanks! Me and my girlfriend scrubbed the interior elephant skin with all sorts of different scrubbers. Used bleach and water, a little spray9 to freshen up the interior walls. It wasn't so bad so I'm pleased with how clean it is now! Not perfect but pretty close.
Old 09-01-2018, 07:49 AM   #19
Hey dave! Thanks for response! I live in halton region just west of Toronto! I just missed the boler 50th stuff this summer. Will have to make it out for the 51st next year!
Old 09-01-2018, 10:04 AM   #20
Raff's Avatar
Awesome job. Great looking trailer. I miss my Boler.
Raff is offline   Reply With Quote
boler
New member New boler owner cadmodel Problem Solving | Owners Helping Owners 5 07-24-2016 01:55 AM
New member! New Boler! (and 2 mysteries) IslandBlue Problem Solving | Owners Helping Owners 6 06-01-2014 08:59 PM
New Boler, new member, first question desy Hi, I am.... 16 02-14-2013 12:19 PM
new member w/ a new boler trailer dmcclure Hi, I am.... 10 08-10-2011 07:40 PM
Junior Member versus Senior Member ? Dave Baston Forum Admin, News & Announcements 5 01-02-2011 07:41 PM
