trillium owners, and others.... - Fiberglass RV
Old 11-23-2010, 03:43 PM   #1
Rarebird's Avatar
Trailer: Trillium 4500
Hello,
We will be replacing the sliding wood doors that are on the front and rear upper cabinets in our Trill. 4500. They are original, very thin plywood that has delaminated.
Have any of you made new ones? If so, what did you make them out of? The same material? Something else? And did you do anything to make them slide better?
We will be replacing all cabinet doors eventually, but these are the worst as they can't even slide in their tracks anymore.
All help appreciated!
Marjie
Rarebird is offline   Reply With Quote
Old 11-23-2010, 09:36 PM   #2
Chris McVeigh's Avatar
Trailer: 1978 Trillium 4500
Our old sliding doors had lost their vinyl covering years ago and the glue left behind made them difficult to slide.
We replaced them using the originals as a pattern - front and rear are different lengths. I found some thin masonite panelboard that already came with a white slightly textured vinyl bonded to it. These were then painted using my favorite off the shelf Trillium color match - Tremclad Recreational White - though it does smell and takes a while to dry.
The hardware was replaced using items found in the section that sells parts for pocket/sliding doors.
Oh so retro
Chris McVeigh is offline   Reply With Quote
Old 11-23-2010, 10:34 PM   #3
Matt in SV's Avatar
Trailer: U-Haul VT16
I like your solution with that textured melamine stuff. I think if you put some paste wax on the edge of the wood, it would help it slide better.
Regards,
Matt
Planning our next Escape!
Matt in SV is offline   Reply With Quote
Old 11-23-2010, 10:59 PM   #4
DannyH's Avatar
Trailer: 1976 Scamp 13 ft
Wow, that looks great. Thanks for sharing.
DannyH is offline   Reply With Quote
Old 11-23-2010, 11:56 PM   #5
Roy in TO's Avatar
Yes, thank you. I just received a parcel today with 95% of the entire rear cabinet. I'll have to check with the shipper to see if they have the two missing peices. This is very timely and informative information.
Chris, is the Tremclad Recreational White, the one on the left or the right? Is that really what the colour is called?
Old 11-24-2010, 05:09 AM   #6
Rarebird's Avatar
Chris,
That looks great, thanks for sharing!
I can't wait to redo ours, they are such a mess I can't open the doors, and I could really use the storage.
Marjie
Old 11-24-2010, 06:35 AM   #7
The off white cover on the left is painted - I could only find white ones when looking for replacements. And yes that's the name of the color - seems appropriate enough.
Old 11-24-2010, 10:56 AM   #8
KevinWA's Avatar
Trailer: Trillium 4500 1978
we used dark stain to make the doors match the rest of the doors in the trailer...this was after the plastic stuff was removed. looks better but you know the deal,,,it always could be better. good luck
KevinWA is offline   Reply With Quote
Old 11-24-2010, 11:06 AM   #9
Roy in TO's Avatar
I've wondered if white plexiglass would not do the trick?
Old 11-28-2010, 10:42 PM   #10
I replaced the ones in my Trillium with FRP panels (Fiberglas Reinforced Panels) same stuff used on bathroom walls in either beige or almond color can't remember which right now. Also used it to totally rebuild the cabinets bottom of them and all.... I'm in the construction business and have pieces left over all the time when we have a job that requires them. really worked out great never will scratch or rott. I need to know where you can find the little spring loaded stops on each of the end pieces......
Old 11-29-2010, 04:26 PM   #11
Hi Randy
The spring loaded stops were found in the hardware department of a large building supply chain store. The enclosed picture might help to identify them. They are put into the top of double interior doors to keep them closed - just a little shorter than the originals so they do not always work at keeping the cabinet doors closed after long road trips. I later thought that something with strong mini magnets might work as well.
Old 11-29-2010, 04:50 PM   #12
Matt in SV's Avatar
The Uhauls have a rivet near the end of the bottom track and a corresponding notch near the bottom end of the panel. To open it you have to stick your finger in the thumb hole and lift it off the rivet shaft. Then it will slide freely. Or as freely as they slide.
Regards,
Matt
Old 11-29-2010, 05:16 PM   #13
Tom U's Avatar
Trailer: Fiber Stream 16 ft
Originally Posted by marjie s. View Post
Hello,
Marjie
Marjie,
We replaced the original sliders (thin plywood - 1/8 or 3/16") WITH 1/8" plexi-glass. You can have it cut to any size or shape and it is not too expensive. The really cool thing is that you can choose your colors - A whole rainbow is available.
ID:	32352 Click image for larger version
Tom - '79 Fiber Stream
There is no such thing as an all black cat.
Tom U is offline   Reply With Quote
Old 05-19-2015, 01:24 PM   #14
Originally Posted by Chris McVeigh View Post
Hi Randy
Chris, do the stops scratch up the doors. We are trying to find a system to keep the doors shut during travel. Thanks
Old 05-19-2015, 07:17 PM   #15
The buttons are on the inside so if there are scratches they would not be seen. This is the same setup as original sliders had, I just made a new set. I find the bolt head for the knob can make a scratch if doors slide completely over each other.
trillium
Happy new Trillium owners Kathleen Gross General Chat 5 08-27-2008 07:04 AM
Question for Trillium 5500 owners Garth M Problem Solving | Owners Helping Owners 8 08-12-2008 06:20 AM
Vintage Trillium Owners Manual mitch Classified Archives 11 12-16-2007 11:38 AM
Trillium Owners near San Francisco Tom Young Problem Solving | Owners Helping Owners 5 01-08-2006 08:41 PM
