Trillium 4500 Wheel Bearing Seals - Fiberglass RV
Old 05-21-2015, 06:46 PM   #1
ckayaker's Avatar
Trailer: Trillium 4500
I need to replace the inner grease seals on my wheel hubs, but don't know what size to get. I was repacking the wheel bearings today and noticed grease had leaked out. On closer inspection I could see the seal had totally deteriorated. Can anyone on the forum enlighten me on what to get...?
Thanks in advance!
ckayaker is offline   Reply With Quote
Old 05-21-2015, 09:22 PM   #2
Your seals should have a number on the metal face. It may be rusty or dirty but usually it can be read. It can also be measured. Any good auto parts store will be able to help.
Old 05-22-2015, 07:12 AM   #3
ckayaker's Avatar
Thanks Jack! The seal was mangled, but I'll have a good look at it for a number. Perhaps I'll pull off the other hub and see if I can find the number on that side.
Old 05-22-2015, 10:21 AM   #4
Trailer: Boler 17 ft
What ever you do, stay away from bearing buddies. More about why later.
Linda Stewart is offline   Reply With Quote
Old 05-22-2015, 02:36 PM   #5
ckayaker's Avatar
Good news, I'm all sealed and rolling again. For future reference for everyone, the seals I used are made by Timken, part #442251, size is 1.718 x 2.561 x 0.500, cost in Canada around $8 each. In the U.S., probably about half that!
So thanks all for your friendly advice! It hard to believe we once lived in caves and the internet didn't exist...
Old 05-25-2015, 12:39 PM   #6
Trailer: '84 Bigfoot b17
Thanks that is helpful part no
Could someone please post up the correct wheel bearing size for 1300 / 4500 trillium trailer w stock axle? I'm going to town right now to pick up 2 of these seals ....I should know what size bearing but don't, I'll try search now too. Just thought having both part # handy for the Napa trip would be helpful for all.
Cheers,
John
Tyhee is offline   Reply With Quote
Old 05-25-2015, 01:56 PM   #7
ckayaker's Avatar
Wish I'd seen your post earlier John when my hub was all apart as I might have been able to read the numbers off my bearings for you. I should have done it anyway now that I think of it. Hopefully we'll get a reply here...
Old 05-25-2015, 10:41 PM   #8
Well that's ok Michael. I'll either take mine apart and read the part # and post up or someone will post up. The Timken part you posted crossed to an SKF part ...I'll post that tomorrow.
Old 05-26-2015, 04:24 PM   #9
Inner grease seal SKF / NAPA part No 17146. Around $12 each Canadian from Napa.
Old 05-31-2015, 09:33 PM   #10
dleverton's Avatar
Happens I just measured the spindle on my Trillium 1300 today. The 1.375" is the inner bearing and the 1.060 is the outer bearing. 1.720 is the seal surface. These are measured on calipers so expect a thou or two error.
Name:	ImageUploadedByFiberglass RV1433129618.123301.jpg
Doug L
Doug
dleverton is offline   Reply With Quote
Old 05-31-2015, 09:49 PM   #11
dleverton's Avatar
Oops, sorry I just realized yours is a 4500 and I don't know if they are the same.
Doug L
Doug
trillium
1976 Trillium 1300 wheel bearing seal size georgewa Modifications, Alterations and Updates 2 08-10-2013 11:44 AM
Wheel bearing grease seals fred boyle Care and Feeding of Molded Fiberglass Trailers 4 02-21-2013 05:53 AM
Size of wheel bearing seals - Bigfoot MountainHome Towing, Hitching, Axles and Running Gear 8 06-14-2010 11:03 PM
Wheel seals for 1974 trillium 4500 Jet Rosas Towing, Hitching, Axles and Running Gear 8 04-29-2008 04:00 PM
Wheel seals for 1974 trillium 4500 Jet Rosas Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
