10-30-2009, 10:50 AM
Trailer: 1974 Perris Pacer
Some pics of the project
10-30-2009, 10:52 AM
Few more
10-30-2009, 10:53 AM
Last one
11-01-2009, 11:22 AM
Hey thanks ill have to check out my local Rv store
Here Pics of the Floor Done
11-09-2009, 11:02 PM
Heres a coulpe pics of the removed front seat and the rear undercoating done( to be painted white)
11-16-2009, 01:53 AM
got the floor 95% in today or i should say tonight
anyways pics tomorow
11-16-2009, 08:33 AM
Trailer: 1971 Astro (ie. Campster/Hunter I)
Jason,
Thanks for the pictures, please keep them coming.
Its hard work but at the end of the job your trailer will return good camping and memories to last.
Harry & Kenna
11-17-2009, 11:02 PM
Trailer: 13 ft Perris Pacer
Been there, done that. It's a messy, tedious job but it's worth it. Looking good so far!
11-18-2009, 12:58 AM
pics of the sub floor
11-18-2009, 01:01 AM
pics of the new floor cut and layed out but not stuck down yet
Finished installing the floor tonight but the next pics will be after seats and quarter round trim are installed
11-18-2009, 01:02 AM
11-19-2009, 10:29 PM
Trailer: 13 ft Compact II
Looks great, Jason! What material is you finished flooring?
Looking forward to your wiring work; I need to do some on mine, too.
Fran
'74 Compact II
11-20-2009, 01:46 AM
The Flooring I finally decided to go with is a vinyl flooring from Lowes, it was just a Roll that they had on the big rack in the back of the store kind of like a bulk deal where I told them how much i wanted and they cut it. I needed seven linear feet because i wanted to do under all the benches too. Plus the fridge and then i still had some left i think im gonna do inside the cubords with the left over
11-22-2009, 01:52 AM
The Flooring I finally decided to go with is a vinyl flooring from Lowes, it was just a Roll that they had on the big rack.
Jason,
I think I used the same stuff. It is Armstrong Vinyl sheet. I did run in wall to wall, and used the leftover to line the low 'cupboard' areas. (I put in foam board insulation first).
Fran
74 compact II
12-02-2009, 06:51 PM
Trailer: 1984 Perris Pacer ('Tillie')
Hi Jason,
Just brought home my "new" '84 pacer! The first thing I did was to pull up the linoleum someone had put down. I am concered the flooring has been wet, haven't figured out yet where it came from?? Anyway... I thought I should replace the plywood, how the heck did you pull out the benches? You have done a SUPER job on your, very impressed!
Vicki
12-02-2009, 08:39 PM
Hey Thanks, Well My benches were riveted in along the edges under the cushions. On the road side the wood that held the bench was rotten so it came right out but on the other side and on the front i had to drill out the rivets to get the benches out.
So I think this would work for you, However I know I have seen Other trailers on here where the benches and cabinets and stuff are all molded Into the Trailer, I think the Bolers are this way(someone please correct me if i am wrong). So with yours being a little newer than mine I can not be sure that your trailer even has rivets.
When I reinstalled the Benches I decided to use machine screws and nuts and washers to install them, just in case I need to remove them any time.As I'm planing a full resto sometime In the future as well
Ill post some pics soon of the benches reinstalled in the trailer
Thanks again for the compliments!
Id love to see pictures of your trailer as well
12-03-2009, 01:37 AM
On the Boler 13's that I have seen, the benches are screwed to wooden cleats around the upper perimeter. The cleats are fiberglassed to the sidewalls of the trailer. The inside/bottom of the benches have wooden cleats fiberglassed to the benches themselves, and then those are screwed into the floor. In other words, a screwdriver would remove the benches from the trailer (well, and a person to carry them!)
I do know that some of the very newest (1980s) Boler 13s made use of fiberglass tabbing where the cabinetry is normally riveted through the shell, but I'm not sure if or how that affected the benches.
Raya
12-19-2009, 11:43 AM
Just about done with the inside of the trailer
I have an old 81 vw camper that i started pillaging for parts
thats where i got the extra little tables, the cutting board and the fold up leg for the table, I need to extend it a little though.
The next big project Will be to steal the furnace from the old vw. and maybe the propane tank and the fridge if it fits better and works.
anyways its pretty much done for now heres some pics
12-19-2009, 11:50 AM
more
12-19-2009, 04:33 PM
Jason,
Glad to see you have been working hard - you have done a fabulous job
My "Tillie" is still sitting in the driveway, waiting for you to come by - you can start any time!!
Did you replace the liner, or is that original? Could you do a couple of pics of the weatherstripping you are using on the door and entrance - I need some ideas!
Vicki
