Fiberstream floor - Fiberglass RV
Old 09-27-2012, 02:03 PM   #1
Trailer: Fiber Stream
Fiberstream floor
Thinking of replacing our "wonderfull Orange Rugging" with a Laminate flooring. What can we expect when we remove the rugging? There is no spring to floor so I would expect plywood. Any suggestions? Thanks
Thelma D is offline   Reply With Quote
Old 09-27-2012, 02:58 PM   #2
Frederick L. Simson's Avatar
The floor is a "sandwich" of 1/2" plywood, indoor-outdoor carpet on top, and thin aluminum sheeting protecting the plywood bottom. The floor sandwich was installed first; then all of the interior was installed on top of the carpet, which is under everything, the bunks, the kitchen cabinets, even under the raised bathroom shower pan and toilet area. You have 2 options:
  1. Cut the carpet with a razor knife around the perimeter of the visible floor and install the new floor covering, leaving the carpet under the bunks, (water tank, battery box) kitchen, bathroom, etc.
  2. unscrew the bunks, (water tank straps, battery box straps) kitchen cabinet, refrigerator cabinet, etc from the floor and try to pull it all out
Frederick - The Scaleman
Old 09-28-2012, 07:34 AM   #3
Victor Benz's Avatar
What Frederick says. I have done mine, have a look here.
The best amateur photography lives on Webshots
I found the thin aluminum sheeting underneath had deteriorated due to galvanic corrosion where the frame and the sheeting met. I cut out the aluminum sheeting with a uitility knife, and let the floor bottom dry out well.
Once I had removed thing inside, I found the floor a little springy. I replaced areas of dry rot, and replaced the old carriage bolts that attached the floor to the frame with elevator bolts. Then I fiberglassed the whole floor and laid lino overtop. Underneath, I used store bought undercoating, initially from a gallon pail, and final coat was the spray stuff. An area of particular concern was the edge of the plywood floor visible from the inside the wheelwells. A lot of water seemed to have wicked in that way.
Victor Benz is offline   Reply With Quote
fiberstream
FiberStream TonyD Problem Solving | Owners Helping Owners 16 08-10-2011 09:37 PM
From PA to OR- got my 86' fiberstream! Cyndivg11 Hi, I am.... 8 04-07-2011 10:04 PM
Fiberstream Help Thelma D Problem Solving | Owners Helping Owners 2 09-23-2010 05:12 PM
fiberstream highlandsgirl Referrals: Molded Fiberglass Trailers 3 09-07-2010 08:19 PM
Fiberstream Andy Towers Care and Feeding of Molded Fiberglass Trailers 14 03-22-2009 08:23 AM
