UHaul wheel replacements - Fiberglass RV
Old 03-03-2017, 07:57 PM   #1
Trailer: 1996 16' Casita SD
Louisiana
Sorry if this has already been covered. I was looking and couldn't find a concise thread on a spare replacement wheel.
I found this-
Chevy Pattern
5 on 4-3/4 5 x 120.65mm
Buick - Regal, Century, Special (most mid-size) '64-'80's
Chevrolet - all (exc as noted elsewhere) '49-'89
Corvette all
Corvair '65-'69 5-bolt
GM compact and midsize
Oldsmobile - 442, Cutlass, F-85, Toronado
(most mid-size) '60's-'80's
Pontiac - GTO, LeMans, Firebird, Grand Prix
(mid size) '64-'80's
I don't know about the offset but figured this is a good start.
itlives is offline   Reply With Quote
Old 03-03-2017, 08:03 PM   #2
The correct wheels are available from Uhaul, they sell them in their eBay store. Sometimes out of stock, but they will put up more eventually. Offset is different than anything else.
Old 03-03-2017, 08:28 PM   #3
Part # for Uhaul wheel; 23516006
Old 03-04-2017, 12:35 AM   #4
Louisiana
Mary and Bob, is that to say I can still buy a new wheel from Uhaul? If so, that's cool!
If not, it would be cool to roll some old Chevy wheels,especially if you have an old Chevy to pull it with!
Old 03-04-2017, 05:09 AM   #5
Yes you can buy a new wheel from Uhaul, but it's on their eBay store. Possibly a big Uhaul service center would sell you one. A Chevy wheel would have the wrong offset and may cause tire rub issues
Old 03-04-2017, 06:59 AM   #6
Louisiana
I learnt two things today. I didn't know UHAUL had an Ebay store, didn't know they sold the wheels and didn't know about the offset. (Math is not my strong point&#129300.
Old 03-07-2017, 06:03 AM   #7
Trailer: UHaul CT13
Iowa
Mike,
I'm a little hesitant to jump in here, re wheels. No expert. But the U-Haul hubs are sometimes replaced with Chevy hubs--either because the original hub went bad [I understand this is rare], or because the PO wanted other options in wheels.
So if you still have 4-bolt wheels, they're likely U-Haul, since the bolt pattern's an odd one.
If they're 5-bolt wheels, the hubs may have been changed out for [from my notes some time ago] "front hub on Late 90's / early 2000's Camaro and Firebird". Seems like there was some Lumina part cross-over as well????? Pretty sure you'd be able to search and find info on this possibility on the U-Haul Facebook page, if not here. [I think Andrew Crevena(?) did this on his U-Haul]
Hopefully I haven't muddied the waters too much here...........
Gary
Old 03-07-2017, 06:42 AM   #8
Part of your info is incorrect Gary, the original Uhaul wheels are 5 bolt, but on a 4 3/4 circle as opposed to most trailer wheels being a 4 1/2 bolt circle. The sealed hubs are attached by 4 bolts to the axle. Yes it is possible to substitute a different GM hub to get the 4 1/2 pattern, but the Uhaul wheel has a unique offset (actually zero offset I believe) so a different wheel could cause clearance issues. I know Andrew made a change to custom wheels but don't recall just how. I kept ours simple with some easy mods preferring using the time to go camping.
Old 03-07-2017, 11:59 AM   #9
Trailer: UHaul CT13
Iowa
Thanks, Bob for adding the additional info. I'm getting to where I trust my memory less & less, so it's good to have back-up.
Gary
Old 03-07-2017, 09:49 PM   #10
Louisiana
My hubs roll very smooth so I'll keep them. Someone said they just carry another tire with them. I'm capable of changing tires in a pinch and that also appeals to me in weight savings.
Right now, I'm pulling with a 2.3L Ranger 4 cylinder. 1,300 lbs is its limit.
It is good to know there are options, though!
Old 04-24-2017, 08:53 PM   #11
Trailer: UHaul CT13
you can go to:
https://www.uhaul.com/TruckSales/Truck-Trailer-Parts/
and find the nearest Uhaul Parts store near you and wheel #23516006, it's white. I just paid $70.00 each and picked up the 2 they had in stock. The parts guy I spoke to said they could order more if needed, this is their most common 13" they use.
jyoshi is offline   Reply With Quote
Old 05-10-2017, 04:18 PM   #12
webbert2's Avatar
Trailer: U-haul
Massachusetts
13" white wheels
I just called my local large Uhaul location and they cannot order these. I spoke to Kelly at the corporate office (1-800 number) and she said they no longer sell these. Does anyone have a direct contact at Uhaul that they recently purchased these? I recently bought an '85 CT and looking to fix her up
Much appreciated!
webbert2 is offline   Reply With Quote
Old 05-10-2017, 04:39 PM   #13
Trailer: UHaul CT13
This is the number of the Uhaul Truck and Trailer Parts location I went to in Sacramento, CA, (916) 635-8292. The parts guy said that this is the same 13" rim they use on most of their trailer, and while I did get the last 2 they had, they could always order more. The box it came in was from US Wheel corp in Huntington Beach, CA part# 23516006, but it's not listed on their website.
Old 05-10-2017, 05:55 PM   #14
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Please be aware that, while the new rims fit the Uhaul, they are not the same as the old, so if you think you can add the very rare original Uhaul hubcaps to the new rims, that is not possible. I speak from experience. We bought the new rims for our VT and then could not use the Uhaul hubcaps that we had. If that is not an issue for you, then it is not an issue. We just used chrome hubcaps to make them look spiffy.
Our Uhaul dealer ordered them for us.
I think it also pertains to other hubcaps too though, like the babymoons.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
Old 05-10-2017, 07:59 PM   #15
webbert2's Avatar
Trailer: U-haul
Massachusetts
Hubcaps
Thanks for the info Cindy, I have the original Uhaul hubcaps and am planning to clean them up and put them back on. Maybe I can use the original wheels and just get new tires mounted on them..
Old 05-10-2017, 08:17 PM   #16
Get the original wheels sandblasted and paint them.
uhaul
Axle replacements 13' trailers Chris L. Towing, Hitching, Axles and Running Gear 2 06-22-2009 07:38 AM
Exterior Door Hinge Replacements THETFORD sewer ROBERT ONEILL Problem Solving | Owners Helping Owners 2 05-18-2009 06:12 PM
Burro window replacements Sarah Noll Problem Solving | Owners Helping Owners 4 11-22-2008 07:00 AM
Direct Replacements for Escape Interor Lights dkdavies Modifications, Alterations and Updates 3 09-18-2007 11:13 PM
Vent Pipe Covers, Where to find replacements Legacy Posts Problem Solving | Owners Helping Owners 5 04-25-2003 09:07 PM
» Trailer Showcase
Dottie
Loulou
Scamp
bippygma
