After several seasons of just taping over the gap in my ‘83 Burro’s incorrectly reinstalled front window, I’ve decided to try and do a proper repair. When I picked it up, the seller just stuck the window frame in place with the two sliding window sections in random grooves and the screen tossed in with all the loose flotsam and jetsam inside.
My problem is that although the lucite seems OK and the latch edge on the inner slide window seems OK, the edge of the other window is bare, so when it is all installled in the original configuration, there is nothing there to seal the closed joint. Does anybody know where I can get this part or what I can substitute there to get a good seal? My alternative will be to go back to my old Plan A and just install a solid, one piece window sealed closed.
Tia ~ Froggie
