how to change the bolts holding a 13'boler to the frame - Fiberglass RV
Old 07-16-2018, 01:35 PM   #1
Trailer: Boler 1975
We just bought out 1975 13' boler this summer and are in the process of renovating. This being our fist attempt at renovating anything, we would need advise on how to change out the original screws/bolts that are holding the shell to the frame. Anyone out there that has come across this?
Chantal is offline   Reply With Quote
Old 07-16-2018, 01:41 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
body to frame bolts
Chantal, welcome to the forum!
My 1974 Boler 13 (since sold) has:
- Four 1/4" bolts with fender washers (on the floor), lock washers (below) and nuts. These four bolts go through the FG floor into flanges that are welded to the rectangular tubing frame. Two of these fasteners are under the front bench. The other two are under the two rear benches.
- Approx. fourteen #10 x 1 1/2" sheet metal screws with fender washers (on the floor) go through the FG floor into the rectangular tubing frame.
All of the above appeared to be original. I replaced all of the fasteners. (Edit: The sheet metal screws were loose. I increased sheet metal screw size to #12 (hex head self drilling screws).)
Good luck,
John
Old 07-16-2018, 05:21 PM   #3
Trailer: Boler 13 77
I also had a lot of screws and bolts to remove. Many were so badly rusted that getting them out was a chore. 3 in 1 oil and Blaster helped loosen some. Occasionally a head broke off which meant digging for the remaining screw portion and using vice grips to unscrew. Needless to say, it was not a quick and simple job. I advise using a rust resistant screw which is compatible with steel in frame for replacement.
Sharylmil is offline   Reply With Quote
Old 07-16-2018, 11:41 PM   #4
Trailer: 1969 Boler 13'
As a suggestion...the nuts will likely be rusted on fairly solidly. Ours sure were lol.
Look into getting a nut splitter from your favorite "tool obtaining emporium"...shear the nuts off and pop the bolts out...easy.
The screws are going to be a pain in the butt.
Al
Gippeto is offline   Reply With Quote
Old 07-17-2018, 01:20 AM   #5
Trailer: Trails West
I could not fit a nut splitter onto the bolts in my trailer so had to come up with plans B, C, D.
I don't have a Boler but recently took out rusted bolts in my trailer. It ended up being a real mixed bag of techniques to get them out. Some were a lot more rusty than others. The first thing to do is put some penetrating oil on them and let them site for a few days adding a little more several times during the day. The next thing to do is use an impact driver to try to take the nuts off. That will so to speak give you the most "bang" for your buck. My rechargeable Makita impact driver was able to remove about a third of them. Then using a pin punch from below drive the shaft of the bolt upwards until you can grab onto it with vise grip pliers.
When that technique failed the next resort was to put a metal cutting blade into a Multi-tool. The blade we used was a DEWALT Dwa4209 Oscillating Titanium Metal Blade. It was held close against the iron under the trailer to essentially slice off the nut and bolt shaft. That got quite a few more bolts removed but let a couple of stubborn ones.
So the last method was to drill the head of the bolt off and use a pin punch to drive the bolt from inside the trailer on out to the bottom. I had mostly carriage bolts so that took a lot of drilling to get the heads off.
Plan E would have been to use an angle grinder to cut the bolts off.
Rusty screws are another set of issues. Sometimes the slots on the top work, often they don't. In that case you can try vise grips, if that fails then drill them out.
Old 07-17-2018, 05:33 AM   #6
removing Boler 13 body to frame bolts and screws
Removing the frame bolts, I got a very strong grip on the head with vise grips, then turned off the nut below. I think all of them broke off, then I pulled out the remains from above.
Removing the screws was actually really quick. The very rusty ones were also very loose (remember they are screwed into the frame). Just pull while turning the head with vise grips. The screws that were still in tight simply unscrewed out. As I mentioned in above post, since the rusty screws were loose, I replaced all screws with #12's. My above post indicates the screw and bolt diameter and length.
Replacing the bolts on the Trillium has proven to be more difficult. Have only replaced 5 of the 8 bolts to date. Will probably use an angle grinder to get the last 3.
Old 07-17-2018, 12:41 PM   #7
bullfrogeh's Avatar
Our '73 Boler had only the typical 14 'screw type fasteners' holding the shell to the frame; and found that half of them had previously 'rusted' off or were significantly loose; when I removed the shell from the frame. I had a 3 in. piece of angle iron welded to the frame near each of the four extreme shell/frame contact corners, and had 3/8 in. holes drilled through the angle-iron pieces. I now have replaced each of the 14 screws, and then also added 3/8 in. stainless bolts with fender washers through the new 'angle-iron' mounts and the shell. I believe the shell is now secure, and well supported, for a further 45 years; although I do intend to replace the fender washers with larger steel plates on the interior shell-surface.
Find yourself; and then others will find you.
bullfrogeh is offline   Reply With Quote
Old 07-17-2018, 03:14 PM   #8
Ian G.'s Avatar
Any sort of hole in a frame is not a good idea, and the boler frame is such thin metal screws don't hold very well
I suggest you use at least 4 square U-Bolts,2"x5"x 5/16" available at most home improvement stores. Locate one in each corner straddling the frame from underneath and bolted under the storage areas inside. I recommend using nylock nuts and cut off the excess thread once tightened.
Old 07-19-2018, 12:38 PM   #9
Trailer: Boler Trailer
The best method I have come up with on my 73 Boler....after I put a new aluminum frame under (well worth the cost) I attached the body to frame using U bolts capturing the frame to the body...4 in the back salon area and two in front ...rock solid.
dust-in is offline   Reply With Quote
Old 08-21-2018, 12:23 AM   #10
Markz's Avatar
Where did you find the aluminum frame?
Old 08-21-2018, 12:24 AM   #11
Markz's Avatar
Where are the 14 sheet metal screws attached?
Old 08-21-2018, 08:56 AM   #12
bullfrogeh's Avatar
Cool
Our '73 Boler had 14 'sheet metal screws/bolts (?) through the shell floor and directly into the frame below. Most (half) of them were rusted out or missing by 2013. I've now replaced them with 'new' similar fasteners (galvanized steel 'roofing screws') and also added four stainless 3/8 in. bolts to 1/2 in angle brackets welded to the frame. At least I now know my shell is way more securely fastened than was originally built, at Earlton, Ont. in 1973. I may also add in the 'u-bolts' as described by Ian.
Old 08-21-2018, 09:54 AM   #13
I live on Vancouver Island , I went to Custom Trailer express in Coombs.....they do an excellent job of making any kind of trailer. Price was $1700 complete. That was 2 years ago. The U Bolts I purchased from a shop in Nanaimo who specialize in leaf Springs for vehicles.
boler
Tie down bolts and frame - old Trillium Randy J. Problem Solving | Owners Helping Owners 30 02-21-2022 01:13 PM
Change this change that jgraps1958 Modifications, Alterations and Updates 17 10-09-2014 08:23 AM
Loose frame bolts and deterioration of floor. Ak Ron Problem Solving | Owners Helping Owners 35 06-07-2013 03:52 AM
Bolts .... frame to body Roland H Problem Solving | Owners Helping Owners 6 09-11-2010 09:08 AM
Floor to frame bolts Tom U Problem Solving | Owners Helping Owners 0 05-10-2009 02:02 PM
