76 Trillium door weather stripping - Fiberglass RV
Old 09-29-2018, 12:05 PM   #1
Trailer: 76 Trillium
Show us [me] how you did the weather strip on your early trillium door and the material used Please and Thank you.
Tipsy is offline   Reply With Quote
Old 09-30-2018, 10:26 AM   #2
Trailer: '78 Trillium 4500
We used pickup truck canopy sealant. Nice and wide, but thin and pretty flexible. Seal isn't perfect, but better than what we had before. This was recommended to us by Claire at the Boler 50th in Winnipeg this past Summer.
Capn.Curt.Wiebe is offline   Reply With Quote
Old 09-30-2018, 01:31 PM   #3
Thanks Capn. Curt. did you mount the seal on the frame or the door.
Old 09-30-2018, 01:59 PM   #4
The original seal on the frame is still in excellent shape, so we replaced the old foam on the door.
Originally I used foam sealant that I bought from Home Depot, but after hearing about the pickup cap sealer from Claire, we decided to try that. It works much better.
Old 09-30-2018, 04:24 PM   #5
Will look into the cap sealer just got back from a 5000 kilometer trip to New Brunswick. Great trip BUT on the way there we had 3 days of monsoon. Kind of put a damper on things [pun intended] so got to seal things up.
Old 10-02-2018, 01:28 PM   #6
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Jimnval, our Trillium 4500 door seal consists of a thin flat foam seal (approx 1/4 by 3/4) on the inside edge of the door, and more importantly a large rubber bulb (3/4" or more) seal with a clip that holds it to the door frame. The bulb seal is thin rubber that has flattened out to conform to the door. This combination of seals works well at keeping out rain and wind. Also, check whether your aluminum drip cap is leaking water at the point where its riveted to the body. You can test by pouring water or with garden hose. Also use a garden hose to test the door seal before, during and after completing the project.
Here are pics of the door frame seal:
Old 10-02-2018, 01:34 PM   #7
Also, the age and condition of the hinges, as well as the how well hinges are fastened to the body affect whether the Trillium door hangs squarely, which affects how well the seals hold water.
We have actually replaced our worn out 40 year old hinges, and installed new hinges using improved hardware (combination of threaded inserts and machine screws).
Old 10-02-2018, 04:10 PM   #8
Absolutely!
Ditto on replacement of the door hinges!
trillium
glue for rubber weather stripping inside Trillium door Gail H Problem Solving | Owners Helping Owners 10 01-25-2013 09:15 PM
Can I replace the weather stripping ? ted saxton Problem Solving | Owners Helping Owners 2 05-24-2009 06:46 PM
new weather stripping carole sullivan Problem Solving | Owners Helping Owners 1 04-25-2008 01:31 PM
Fiber Stream Door's Weather Stripping Charlie D Problem Solving | Owners Helping Owners 4 05-23-2006 09:47 PM
