1994 Bigfoot door weather stripping - Fiberglass RV
Old 10-22-2018, 10:37 AM   #1
Trailer: Bigfoot 17G
My trailer door (solid door, not screen door) has a rather unique kind of weather stripping that is shaped like the diagram below. The "T" runs in a channel in the aluminum frame of the door. Has anyone out there ever replaced this on his/her rig and, if so, where did you find the material and how did you fit it into the channels which appear to be closed off at each end? Thanks.
bobblangley is offline   Reply With Quote
Old 10-22-2018, 08:40 PM   #2
mszabo's Avatar
Trailer: U-Haul VT16
https://www.vintagetrailersupply.com...p/vts-2003.htm
mszabo is offline   Reply With Quote
Old 10-23-2018, 01:25 AM   #3
Trailer: Trails West
To get a match you need to know the dimensions as well as the shape. That particular profile comes in several sizes. The width and thickness of the base has to be correct or it won't fit into the slot in the door. The height of the bulb has to be right, too short and it won't compress enough to keep out the water. Too high and the door won't close.
As to fitting it into the channel, it is flexible. You flex the edges of the base towards each other to get it into the slot then let go. One useful thing you can do to lubricate the seal for easier installation is apply some glycerine so it slides in with a lot less resistance. Glycerine is a very slippery liquid. But since you need to keep a grip on it so you can push it around while you install it brush the glycerine inside the track and not onto seal. Or at least apply it only on the lower flange of the seal and not on the bulb.
Glycerine will not hurt the seal or cause it to deteriorate. Some car makers recommend applying it to the door seals to keep them flexible and reduce the rubbing friction on them.
Old 04-09-2023, 02:02 PM   #4
Trailer: Bigfoot 17
BRITISH COLUMBIA
Bigfoot weather stripping
I have the same weather stripping on my 1992 17' trailer which needs replacing. Any idea where to purchase this profile of gasket?
Expresso is offline   Reply With Quote
bigfoot
76 Trillium door weather stripping Tipsy General Chat 7 10-02-2018 04:10 PM
glue for rubber weather stripping inside Trillium door Gail H Problem Solving | Owners Helping Owners 10 01-25-2013 09:15 PM
Can I replace the weather stripping ? ted saxton Problem Solving | Owners Helping Owners 2 05-24-2009 06:46 PM
new weather stripping carole sullivan Problem Solving | Owners Helping Owners 1 04-25-2008 01:31 PM
Fiber Stream Door's Weather Stripping Charlie D Problem Solving | Owners Helping Owners 4 05-23-2006 09:47 PM
