Leaf spring vs torsion axle: 1998 Scamp 13' - Fiberglass RV
Old 06-27-2014, 03:30 AM   #1
Idaho
I posted this in another forum before realizing it should probably go here. I've just started working on my 1998 Scamp 13' and am curious about the pros/cons between the two types of axles. I'm leaning toward the leaf spring because it's cheaper to purchase, install, and maintain but am curious if this will change anything about that towing, etc of the trailer. Also wanting a bit more clearance so looking into 15" tires but am also curious about whether I'll need a lift kit as well. Any information you can provide will be extremely helpful!! Thank you so much in advance!!
katidesc13 is offline   Reply With Quote
Old 06-27-2014, 07:25 AM   #2
The Minimalist's Avatar
Trailer: 08 Weiscraft Little Joe 14 Subaru Outback 2.5i CVT
Louisiana
If you are considering a torsion axle and want to increase your tire size, may I recommend going to Dexter Axle - Trailer Axles and Running Gear Components - Home. There is a wealth of information and some handy downloads, which will help you in your decisions. They cover both torsion and sprung axles.
I would recommend the Applications Manual as handy literature to any trailer owner.
Clif
The Minimalist is offline   Reply With Quote
Old 06-27-2014, 07:47 AM   #3
Idaho
Thanks Clif! I've actually been on their site before as I've seen mention of their name numerous times on this site. I'm more curious about the difference between the two axles and the pros/cons. I'd prefer to save some money initially and just go with the spring but wasn't sure if it would make sense since I'd like more clearance and bigger tires.
Old 06-27-2014, 07:57 AM   #4
Roy in TO's Avatar
2 thoughts.
Torsion axles also have a shock absorbing action, leaf springs do not.
Think about where the leaf is going to attach on the forward portion by the door.
I've posted a lot of information on torsion axles in this thread:
http://www.fiberglassrv.com/forums/f...arm-37248.html
My advice is to spend the time doing the research and planning before starting the project.
Old 06-27-2014, 09:02 AM   #5
Timber Wolf's Avatar
North Florida
While I personally have the knowledge, skill, ability, tools, equipment and facilities to change from a torsion axle to a leaf spring set-up at the end of the day when I did my Scamp I went back with a torsion axle, albeit a “stronger” one. I also went back with 13" wheels & tires although I did verify that 14" would clear and work fine. I saw no advantage to raising the trailer at this time and with the bolt-on brackets of the new axle I could easily (and cheaply) raise the trailer later if desired.
A torsion axle has real advantages particularly in an installation such as under an egg trailer. I personally believe it has dampening and independent acting characteristics that helps our aging eggs from getting beat to death, a real consideration to me. I am not doing all this work on my Scamp just to have to do it again or to create other problems I will have to solve/deal with down the road. I am already concerned that going to a 3500 pound axle introduced new stresses to the trailer, I did not want to compound that by also changing the attachment points. That said, a 13 footer is smaller, lighter, and shorter (less mass forward and aft of the spring perches) than my 16 and therefore the ramifications of an axle swap should be of less concern.
All that said, if 15” wheels & tires are really what I want (and I cannot imagine a scenario where it would be) I would seriously investigate a traditional leaf spring axle. The axle would be cheaper and probably available locally. The installation time and trouble would be similar although more involved as you would have four points to deal with instead of two.
Old 06-27-2014, 10:05 AM   #6
Trailer: 2010 Scamp 16
Reading what Tim said I would add that you really have six points of attachment to work out for yourself. Four for the leaf spring mounts, plus two shock absorbers. Without shocks I think a 13 ft. would go down the road like Tigger on a sugar rush (oh the legs are made of the rubber, the tail is made of a spring, that Tigger).
I suppose with some care one could have leafs that were tuned to the load that would bounce less but I'm betting you would really need shock absorbers too.
Old 06-27-2014, 03:08 PM   #7
Idaho
Wow, this is really helpful!! Not having ANY experience with this, there are many things I didn't consider in my original thoughts. The idea of 15" tires actually came from another post here. She stated she used a Dexter 45 degree down axle and was able to use 15" tires to lift the clearance a total of 6". As it sits, I may just put new tires on it for now and save the money for the torsion axle. Just feel like it's an entire new language I'm learning!! Thanks all!!
Old 06-27-2014, 04:02 PM   #8
Bob Miller's Avatar
Trailer: Class A Motorhome
Unless you are going to tow off-road with a 4x4 rock crawler, why do you need all that extra clearance????? Also realize that raising the trailer also raises the center of gravity and reduces stability, especially in cross winds.
Old 06-27-2014, 04:10 PM   #9
Idaho
I'm very new to this whole thing, so I'm not sure exactly how much clearance I would need. I will be doing backcountry excursion where the minimal clearance I have now will likely high-center or drag. I've just been basing my information off of other posts as I have no personal point of reference.
A little more information: I am a travel RN and I will be full-timing in this trailer starting in mid September. Though the majority of my travel will be in established campgrounds, etc. there will also be many times I will be traveling "off grid" and will likely run into less developed dirt trails in the backcountry. I figure if I'm going to invest in a new axle and/or tires, I may as well try to put the money into it to get the little extra clearance I may need at a later point. If you have any other suggestions/information, I would be greatly appreciative! Thanks!
Old 06-27-2014, 04:23 PM   #10
Roy in TO's Avatar
FWIW I measured my 4x4 Rangers clearance the other day. I think it was for the battery box thread. There is 7" of clearance before you hit the differential.
If I recall the calculations right on the early bolers and Scamps. The total height minus the inside height gives a kitchen floor height of about 10". Take off a few inches for the wood and underlying subframe on the floor, you are probably looking at 8" clearance in a stock configuration. Which is more than my 4x4.
Just putting things into perspective.
Old 06-27-2014, 04:32 PM   #11
Roy in TO's Avatar
Replacing a dead axle with the same specs will give you about 2" more clearance. Adding the "high lift" mount on Dexters will give you 1" more. The bolt on brackets will provide another 1/4"
How much clearance do you have now? And how much on your tow vehicle?
Old 06-27-2014, 11:35 PM   #12
Idaho
I haven't measured my current clearance but just looking at it, it's not much. I drive a 2010 tacoma so my tow vehicle had plenty of clearance. Thanks for the info! I may be just fine with the high lift dexter axle replacement.
Old 06-28-2014, 06:31 AM   #13
I believe I'm the "she" referenced in this post . Yes, my Scamp runs 15" tires, sits taller than most. But, I pull with a truck and the trailer tows beautifully. Never regret one about my decision. Although now what I know, I would have gone with a 22 degree down and used a spacer to lift the trailer.
Old 06-28-2014, 06:36 AM   #14
Idaho
I believe you are!! Why the 22 instead of the 45 you installed?
Old 06-28-2014, 06:46 AM   #15
Because I (think) I finally figured out a good way to rework the discharge plumbing to one valve. But, it would require space between the trailer floor and the axle. Hence the spacer which using a 45 degree down doesn't need. Remember, I have a 16' trailer with a bathroom.
Old 06-29-2014, 09:56 AM   #16
Roy in TO's Avatar
Another thing I just remembered. The metric tires that replace the original 6.000 x 13 tires of early trailers have larger diameters. Today's tires will give you approximately another 1/2 to 1" more clearance.
Old 06-29-2014, 07:43 PM   #17
Idaho
Based on all this feedback I've come to a couple conclusions:
1) I'm leaning more towards sticking with the torsion axle. Although it's more expensive initially, it sounds like the install is a little less complicated because the dimensions and contact points are similar to what already exists on the trailer.
2) I will likely not need near as much clearance as I originally thought.
3) I have SOOOOO much research to do and I'm a little overwhelmed with the technical side of this project. Wishing I had someone a bit more experienced in this here to walk me through it. I've a very visual person, and trying to understand all the specifications and terms is really hard without visually SEEING what it is we're talking about. The Dexter resource library has been VERY helpful!!! Thanks for the suggestion!!
For now, I am having a friend look at the trailer to evaluate the quality of the current axle. If it's still in decent condition, I will probably just get new tires until I can invest the money in a new Dexter torsion axle and a little bigger tires. I'm still uncertain whether I should stick with the 22 1/2 degree down or go up to the 45 degree down axle (again, more research). I only have until September before I'm full-timing in it, so I need to make the most efficient, cost-effective decisions now.
Thanks for all your feedback!!
axle, scamp
Leaf spring vs torsion axle: 1998 Scamp 13' katidesc13 Problem Solving | Owners Helping Owners 6 06-27-2014 03:36 PM
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
torsion springs or leaf springs Cat futrell Problem Solving | Owners Helping Owners 18 08-26-2012 08:12 AM
1975 Scamp 13 leaf spring conversion? pudgepuss Towing, Hitching, Axles and Running Gear 10 07-23-2011 09:39 PM
Leaf Spring/Axle replacement for a Scamp 13 DanMurphy Towing, Hitching, Axles and Running Gear 8 02-16-2008 02:56 PM
