12-02-2017, 09:48 PM
Trailer: Parkliner 2014
Georgia
Winterizing 2014 Parkliner
Any tips? Never done this before. From what I can see I don't have a water heater bypass already installed; looks like there's a valve on the cold water in tube and one on the red tube, although it seems a little far down the line since is after two red tubes branch off under the kitchen sink and the valve is down as the red tube heads into the floor (I guess thats headed to the shower/bathroom sink but why two lines going under the kitchen sink?). Am I correct that I need to run out and get a water pump conversion kit (I guess that's what it's called)? That and the bypass above are just fittings and tubes?
And my unit has two fresh water tanks, under each of the back benches. Does that make this more involved? I guess it scrunches things on the HW tank side, but other than making my big arms a problem, any issues?
Thanks.
12-03-2017, 07:30 AM
Only thing I know about a Parkliner is the one that belongs to friends had two drain valves inside, on the curb (door) side that were hard to find or reach. When opened they dumped water out to the rear of the wheel. I believe they drained both the hot and cold water lines. Don't know if yours is the same, but it's something to look for.
12-03-2017, 08:00 AM
Just curious...Is winterizing necessary in Georgia? Perhaps in the area north of Atlanta? Would draining all the lines just be enough? We are heading through Georgia to Florida in a few weeks and planned to de-winterize during our one night stay in Nashville on the way down. Of course, we will wait another night for farther south if the forecast is frigid!
12-03-2017, 10:15 AM
Georgia
Maybe not immediately. A couple of nights down to 29 or so are expected by the end of the week but it's currently in my driveway so I can put a heater in. But even in a mildish winter I'd expect a couple of consecutive nights at 20 or less with high barely above freezing. And I've seen three days or so with it never breaking out of sub freezing temps and lows even in single digits.Oh and I'm in Atlanta.
And as I said, I'm new and need to learn this stuff.
12-03-2017, 10:26 AM
NW Wisconsin
We were camped in SE Georgia along the Florida Georgia line and woke up 2 mornings in a row with temps in the upper 20's
We camped in Northern Georgia and woke up to a nice blanket of snow.
We have camped in Southern Illinois on our way South and experienced night time temperatures well below zero
Then you get to central Florida with temps in the 90's and 100% humidity and Southern Illinois starts to sound really nice
12-03-2017, 10:49 AM
Trailer: Parkliner
Under the bench in back that is closest to the water and electric connections there is a valve handle that you turn 90 degrees to allow the water to drain from the pipes. Jack the front end up slightly to help flow towards waste water tank and outside drain.
12-03-2017, 12:02 PM
Trailer: ParkLiner
Virginia
Check out 4th post in this thread.
http://www.fiberglassrv.com/forums/f...ual-82888.html
The hot water drain is right below the cold water drain. You might not be able to see it, so just feel around under the cold water drain until you find it.
12-03-2017, 01:03 PM
Georgia
Thanks for all of those responses, especially the thread link, Huck. I'll post some specific questions there but I gather I don't need a water heater bypass kit or pump kit that I've seen referred to in other, more general posts, and that there is no antifreeze in the red hot water lines (how are we sure they're dry? Just because that drain stays open?).
12-03-2017, 01:15 PM
Last week we were at Magnolia Springs State Park which is sorta northern GA I think. At 7AM it was 32 degrees one morning. Now inland from Fort Meyers Florida they are predicting a cold front the end of the week, 70's during the day, mid 50's at night LOL. Otherwise low to mid 80's, low humidity and a nice breeze as we sit and watch big boats passing by on the Caloosahatchee River. Other years at Jekyll Island GA, on the coast just above the Florida border it went below freezing a few nights, but that was probably in January or maybe Feb.
12-03-2017, 01:21 PM
Trailer: ParkLiner
Virginia
I bought my Parkliner in Jan 2014 and it came with a hot water tank bypass. Look in front and slightly to the right of the hot water tank and you should see a lever that looks like the drain levers.
12-03-2017, 03:17 PM
Considering your "mild" climate, you may get by just by draining the water tank, water heater and lines, and blowing them out with air. But, pour RV antifreeze into the toilet and flush it down. Also pour some in the the shower drain and flush that down. Our 2016 Parkliner has two drain valves just ahead of the water heater and down low in that compartment, one below the other. kinda hard to see. I can e-mail you pictures if you send me your e-mail address, to
Lwgcollins@aol.com.
12-03-2017, 03:45 PM
Trailer: Parkliner
If you'll send me your email address, I'll mail you the complete winterizing instructions put together by Parkliner.
12-03-2017, 06:11 PM
Trailer: 2014 Parkliner 2016 Honda Pilot
I purchased mine in Nov 2014, and it has the same lever. Let me know if you'd like pictures. -- Anne
12-03-2017, 08:12 PM
Georgia
Thanks all. Wayne and Thomas I've sent you my email by private message regarding your kind offers.
So under my curbside bench/bed there are three valves; on the drain lines for both hot and cold, which are a little challenging to access. And to the rear (right) of the water heater, one valve on the tube going into the heater tank. That's the "bypass valve" but threw me a bit because other descriptions and pictures I'd seen show a bypass that cuts off the input but then returns to the hot water line; turning both those valves would allow flow to bypass the tank but still get antifreeze into the hot water lines to the sink and shower. But with PL's system, there's no antifreeze in those lines, right? So if there's some water left in there, isn't there some risk of freeze damage?
If I blow air through everything in the system before the procedure in Huck's link, I guess I need to have the valve on the input line to the water heater open and the hot drain closed, then reverse each of those two valves before putting antifreeze in (so with air running through the water heater tank; but there's got to be some sediment in there)? Although I'd probably then decide Wayne's suggestion is good - if air is all that's done for the hot lines why put antifreeze in the cold lines if they both got the the same air treatment? If it's good enough for the hot lines shouldn't it be good enough for the cold ones?
Probably overthinking some. But my neighbors related a problem with a pop up that happened when they under thought.
12-03-2017, 08:17 PM
Trailer: Scamp 16
Kevin, we travelled from IL thru TN and AL down to FL, and have seen snow as far south as AL more than once. Personally I wouldn't add water until you get to FL. Safe Travels.
Tom
12-04-2017, 08:21 AM
Trailer: ParkLiner
Virginia
There might be some water left in holding tank, so by dumping antifreeze in, you are protecting your holding tank as well as pumping antifreeze through the cold water pipe so you can run some into the kitchen drain, shower, toilet, and bathroom drain.
I think about the only place water might collect is at the entry into the bathroom, and that would be if the line doesn't drain properly when you open the cold and hot water drains.
Last winter I winterized my Parkliner in December and headed to the Gulf in early February. I used the city water hookup, not the holding tank, while camping; so when I returned I just added some more antifreeze (about 1/2 gallon) and ran it through the cold water pipe and flushed some into the drains and toilet.
What I did that helped me understand how to winterize was to open everything up and look at how the water traveled through the trailer. Once I understood that, it was easy to understand how to winterize and de-winterize.
12-05-2017, 02:11 PM
Georgia
Thanks again to all; pink came out of all the fixtures and went down all the drains, basically per the procedure in Huck's link. Tom sent me a copy of the original mailing from Parkliner/Chandler and the only real difference is that there's another footnote that says if, like mine, your unit has dual freshwater tanks, to put antifreeze in the starboard tank. Not sure if that meant "both" or "instead of" but decided belt and suspenders, so did both.
12-05-2017, 03:38 PM
Tom
When we were living in Atlanta, we went home one year at Christmas to Illinois. Only snow we saw was at our Atlanta house......
I wouldn't add water until I was in Florida, unless you travel along the GA coast.
12-06-2017, 09:07 AM
Missouri
steve how did you keep want in that wx below zero?
thanks
bob
12-06-2017, 12:24 PM
Trailer: 2012 ParkLiner #006
I installed a hot water bypass in mine as well as a drain for my single freshwater tank. Not sure what to tell you. Maybe a trip to a local RV place and ask them what they suggest?
Best of luck to you.
Frank
2012 ParkLiner #006
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
2014 Ford Escape VS 2014 Jeep Cheorkee for Casita SD
zdr |
Towing, Hitching, Axles and Running Gear |
97 |
10-22-2019 08:23 AM |
Winterizing Question - Parkliner
Huck |
Care and Feeding of Molded Fiberglass Trailers |
21 |
11-04-2014 01:32 PM |
ON | 2014, May 23-25: EggFestOntario for 2014 is back
Vivian L |
Rallies, Get-togethers, Molded Meets (Archive) |
13 |
09-18-2014 07:27 AM |
OR | 2014, April 24-27: Spring NOG 2014 – Northern Oregon Gathering
Donna D. |
94 |
05-01-2014 06:41 PM |
FL | 2014, Feb. 10-14: Scamp Camp 2014
Mike Sullivan |
39 |
02-09-2014 07:36 AM |
