1975 Boler Complete Restoration....my once in a lifetime project! - Page 9 - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Modifications, Alterations and Updates
Old 06-15-2020, 09:12 AM   #161
Trailer: 1975 13' Boler
Some "before" pics of the interior. There was MUCH filling, sanding, filling, sanding.... I was going to do a section at a time when building the cabinets but I thought I'd make a big mess once, get the plywood all sealed up and get the really yucky job done! Now I can just enjoy building cabinets and making everything look nice!! Should have it painted by the end of the week. Stay tuned for the "after" photos
Shanos is offline   Reply With Quote
Old 06-25-2020, 07:10 AM   #162
Ok....the "after" photos. Painting the interior is the last of the big, often tedious, jobs!! It is now a blank slate, ready for cabinets which is the fun part!! It's been a long road to get to this point.
Old 06-25-2020, 07:16 AM   #163
Installation of the galley cabinet. Drawer fronts and cabinet doors to add after the electrical work which will be next week!
Old 06-25-2020, 07:26 AM   #164
And the closet...doors to be made and installed. Next step is to run all of the wiring for the fixtures, shore power and battery charger....next week!
Old 06-25-2020, 07:31 AM   #165
FRED SMAILES's Avatar
Trailer: 13 ft Boler
One of the best rebuilds on the site IMO!!
All the adjectives I know have been said, keep it up!
Thank you for taking the time to share the pictures and story with us.
Fred
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
Old 06-25-2020, 09:11 AM   #166
Hi Fred, thank you for your very kind words!! Not to be immodest, but now that I'm at this point, I look at my Boler and I have to pinch myself! It's so much more than I originally envisioned! And, you're welcome! I'm happy to share my project
Old 06-29-2020, 10:41 AM   #167
Trailer: perris pacer
Hello Shanos
That looks awesome and it’s encouraging. We have a 74 Perris Pacer that we have gutted and now I’m struggling with what to do on interior surfaces. What is that on your walls? Is there a layer of insulation? Where will you run electrical stuff if this is the final surface? So many questions. Your cabinets are great. I will be doing the same as ours were thrashed.
Can’t wait to see the rest .
Oldskater68 is offline   Reply With Quote
Old 06-30-2020, 07:19 AM   #168
Hi Patrick, happy to answer your "lots of questions"!
If you go back to page 3 of my thread, that's where the posts about the insulation and wall covering begins. I have 1" "ribs" made up of 4 layers of bending plywood with spray foam insulation between them. On top of that I glued pieces of 3 mm bending plywood called Lite Ply cut and fit (see pages 6 and 7). This was a tremendous amount of work! Before I put the "ribs" in I glued lengths of flexible conduit with "junction boxes" at each end to run electrical wire after the paneling was up (see posts 60 and 61). This is what I'm doing right now and it's worked very well! I'll post some pics once I'm finished working with my friend who is an electrician.
You should also look at the threads by Robert Johans. He's done some renovations from bare shells (1974 Boler Resto. Oops, I did it again...) He glues Reflectix on the shell for insulation and uses blocks to attach cabinets. He uses a fabric on top of the Reflectix. You can check the details in my post as to why I didn't end of doing that. Robert also renovated a Perris Pacer...see 1982 Perris Pacer Renovation
I hope that helps Patrick!
Cheers,
Shannon
Old 01-29-2021, 05:18 PM   #169
Wow...it's been a while since I've posted. I've taken a little break from my Boler but have been working with my electrician friend installing the 12 and 120V electrical systems. Way more complicated than I every thought but super happy with the results. I chose Redarc's battery manager system to control re-charging and monitoring my batteries. It will charge from either 120V, 12 volt from my car when driving or from solar panels (later addition). It's a pricier charger but it does everything and makes it pretty simple!! Left room at the bottom of my closet...
Old 01-29-2021, 05:29 PM   #170
There was way more wires than I ever thought would be required so there was some "tidying up" to do! Here's some "before and after" shots. I used split wire loom and made some "junction boxes" when there were wires travelling in more than one direction. Protects all the wiring and looks neat and tidy.
Old 01-29-2021, 05:39 PM   #171
Trailer: 1975 Triple E Surfside
Nice work ! I like tidy stuff.. I'm now working on trailer number three.. A surf Side.. Wood cabinets like you are doing
Retired and love new projects.. and blog about them
https://www.robeye.ca
robeye is offline   Reply With Quote
Old 01-29-2021, 05:43 PM   #172
After much research and consideration, I decided to go with lithium iron phosphate batteries. I didn't want to worry about maintaining flooded cell batteries, I could install them inside the trailer taking some weight off the tongue and could get longer usage from them without worrying about discharging them too deeply. They are much more convenient and you pay for convenience! Battleborn batteries come with a great warranty so I expect I'll enjoy these for a long time! I'm only doing this once!!
I made battery boxes to protect the batteries and anyone from accidentally touching the two terminals.
Old 01-29-2021, 05:46 PM   #173
Rear of the trailer is now ready for the lockers which will support a permanent bed, storage accessed by the side baggage doors and a small fresh water tank at the rear. I've started on those and will be getting through the remaining cabinetry over the next few months in anticipation of a camping summer!!
Old 01-29-2021, 05:55 PM   #174
My other addition was to build a front window cover. I had the unhappy experience of finding the front window inside the trailer when we were towing it back from a road trip this past summer!! I guess the wind pressure was too great for the gasket holding the front window in place. It was a "no harm, no foul" situation and was solved by a cover. No problems on the next road trip! I used Lexan so I could still see through the trailer at traffic behind me...works well. I ordered the stainless steel window gravel guard hardware from Camping Treasures.com so no worries about rust in the future.
Old 01-29-2021, 05:58 PM   #175
And...running lights on and interior lights for the first time was pretty fun!!
Old 01-29-2021, 06:03 PM   #176
Hi Rob, Thanks! I like things neat and tidy as well. Wow...trailer #3...I've only got one in me!!
Old 01-29-2021, 09:53 PM   #177
Trailer: Boler 1300
Looking great Shannon!! Nice to see the progress.
bobdobqb is offline   Reply With Quote
Old 01-29-2021, 11:57 PM   #178
Thanks Bob!
Old 01-30-2021, 06:33 PM   #179
Jay H's Avatar
Trailer: Boler 1300
Looking really sharp Shannon!
Love the lexan rock guard.
Old 01-30-2021, 08:15 PM   #180
Thanks Jay!
boler
WA | SOLD: 1975 - 14' CareFree - Unfinished Restoration Project David Morgan Classified Archives 3 09-01-2017 04:08 PM
Costco has the Lifetime® Camping Tent Trailer ShawnKK General Chat 10 10-23-2013 09:55 PM
A camping of a lifetime Henryk Camping, Campout Reports 12 03-26-2006 06:17 PM
torsion axle lifetime? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 17 07-10-2003 07:46 PM
A camping of a lifetime General Chat 0 01-01-1970 12:00 AM
