dometic fridge doesnt work on ac - Fiberglass RV
Old 06-15-2019, 02:54 PM   #1
our fridge has stopped working on ac. is there, are there any fuses or such like to check. I have power to the electrical outlet. fridge works ok on propane.
robinns is offline   Reply With Quote
Old 06-15-2019, 07:27 PM   #2
member
Isle of Wight
Maybe the electric element went South.
Google for the repair manual for your fridge - here is an example... https://fourwheelcampers.com/NewDome...atorManual.pdf
WizWid is offline   Reply With Quote
Old 06-16-2019, 05:10 AM   #3
Trailer: Casita Patriot
i'd first check to see if the thing was properly plugged into the outlet. they can vibrate loose in some cases. then check the fuses/breakers at the converter (remember, you can't assume a fuse is good if it looks good, check it with your meter). if all is good in those places then use that meter to determine if power is getting to the fridge. if yes, then start thinking about replacing the electric element. widgetwizard's suggestion about dometic's repair manual is a great one...there's also most likely some youtube videos on troubleshooting you could refer to.
p@
patrick crawford is offline   Reply With Quote
boler, fridge
RV propane issues, Dometic fridge recall & intermittent fridge problem mcmars Problem Solving | Owners Helping Owners 19 10-25-2018 05:00 PM
Dometic refrigerator Model RM 2354, stop to work when traveling . Gilles Problem Solving | Owners Helping Owners 6 07-25-2016 12:18 PM
Separate Bedrooms/Separate Campers---doesnt get much better than this! Vickie B. General Chat 5 09-02-2013 09:49 AM
Fridge won't work on 12v Flygal Problem Solving | Owners Helping Owners 3 07-12-2008 10:37 PM
Fridge Doesn't work on AC donalie Problem Solving | Owners Helping Owners 3 06-03-2008 08:38 PM
