Hepvo waterless trap on Casita - Fiberglass RV
Old 07-13-2009, 01:36 PM   #1
shane n's Avatar
While out camping I did the HEPvO waterless trap thing. Pretty easy and had to glue just one connection. No more p-trap, shower valve or going outside wet and naked at 5:00 am to open the shower drain.
shane n is offline   Reply With Quote
Old 07-13-2009, 02:08 PM   #2
Al V's Avatar
Trailer: 2005 17 ft Casita Freedom Deluxe
Send a message via Yahoo to Al V
what stops water from going up in to the shower? like what happens when you for get to shut the drain valve.
Al V is offline   Reply With Quote
Old 07-13-2009, 03:03 PM   #3
Phil Underwood's Avatar
Trailer: Bigfoot 21ft (25B21RB)
excellent write up on it here, have to be a member to read and view the pics though
http://www.casitaforum.com/invboard/...showtopic=3493
Phil & Denise Underwood
1973 13ft Lovebug
1998 17ftCasita FD
Phil Underwood is offline   Reply With Quote
Old 07-13-2009, 03:50 PM   #4
Al V's Avatar
neat read! sound like a great mod
Old 07-14-2009, 11:04 AM   #5
Trailer: Former Casita 17 ft owner
Shane,
Because your Hepvo valve and the line is below the level of the entry to the tank, you will have water standing in that part of the plumbing.
All the other similar mods I've seen (On Casita Forum), kept the plumbing at or above the level of the entry to the gray water tank.
Morgan is offline   Reply With Quote
Old 07-14-2009, 01:44 PM   #6
shane n's Avatar
Shane,
The plumbing is not lower than the original I cut off. When I cut it off with an empty tank I had water in the plumbing. The valve itself should slope down, not level or uphill just to keep plumbing tight against the bottom of trailer. Every trailer is different and plumbing will vary. My application is higher than the original plumbing and the shower drains fast or faster with no back up. The little water in the line don't mean a thing and every trailer will have some regardless of the plumbing.
Old 07-15-2009, 06:07 PM   #7
shane n's Avatar
OK, I re-plumbed my hepvo valve. I had clearance issues with the factory pipes so I cheated and used a flex coupling. I hope this time I get a passing grade.
Old 07-15-2009, 08:13 PM   #8
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
Looks good Shane!
brian
2003 Casita SD 17'
https://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
casita
Shower trap same as the sink trap in a Scamp? Bryan L. Plumbing | Systems and Fixtures 6 01-14-2010 02:56 PM
How to remove drum trap on sink? Kevin Dyck Problem Solving | Owners Helping Owners 3 06-25-2009 10:03 PM
No Longer - Trade 17' Casita for 13' or 16' Casita, Scamp, pennyg Classified Archives 11 03-04-2007 09:38 PM
