08-30-2018, 04:36 PM
Trailer: Trillium 1300
Newfoundland and Labrador
Modded 75 trillium 1300 frame
New frame coming along for my 75 trillium. It's 4 feet longer in the front and going to have cargo space there. Here are a couple of early shots of it almost done.
08-30-2018, 04:37 PM
What's your projected tongue weight? Looks like it will be significant.
08-30-2018, 04:45 PM
Nah, got it made 2 feet longer on the back too and will house the propane and batteries and water. The front carbon will be for stuff like extra propane, coolers, bbq etc. Not too worried about the tongue weight realy, always tow with the truck
08-31-2018, 01:18 PM
Trailer: 1971 Hunter compact Jr, 1979 Terry 19', 2003 Scamp 16'
It does not matter what you tow with. If the trailer starts to sway because the tongue is to light you can be in trouble in a hurry.
When towing my 1100 lb. compact jr. with my 1 ton van I made the mistake of putting 2 boxes of camp wood in the back door just before I left. Going down the free way at 59 mph it started to sway badly. I barely got it under control. Removed the wood and all was well. I had been hauling wood that way for five years with know problem. That time I did not load the front the same as in the past and the tongue was to light.
08-31-2018, 05:06 PM
The tongue weight on my new frame will be significantly higher with the much heavier steel and 4 extra feet in front of the wheels. The small deck trailer will be loaded and I think it will tow awesome.
08-31-2018, 10:16 PM
Trailer: Compact Jr
TX
Looks great! What size tube are you using?
I am planning a similar frame fo my compact jr
09-01-2018, 06:58 AM
Same as the old one, 2x3" but with a much thicker wall. Very sturdy.
09-06-2018, 11:20 AM
Trailer is on the frame today.
09-07-2018, 04:36 PM
Few more from today, showing off the scissor jack's welded on and the tool box going on.
09-07-2018, 07:05 PM
Looks like you have a bit of a belly band issue. It also looks like the cab is a bit too far back, judging by where the wheel sits in the well. I assume you have not bolted it down yet. How long is your frame from coupler to bumper?
09-08-2018, 02:40 PM
We are deleting the belly band. The trailer is now 18ft long, she is perfectly centered though, must be the angle. Actually on that picture she was still on the blocks still being aligned
09-11-2018, 01:41 PM
Here she is bolted onto the new frame.
09-12-2018, 11:44 AM
Trailer: Trillium
Saskatchewan
Great Work!
I have a '74 1300 Trillium and really like this idea. Would you be willing to post dimensions, material used, axle used and specs, etc? It would be great to have some extra room for storage.
Cheers,
Murray
09-13-2018, 04:11 AM
Trailer: Former 1978 Trillium 4500 owner (now 2010 R-pod)
I wonder if the money spent on this modified frame will result in an increased value when it comes time to sell or if it will be seen as devalued compared to an original trailer.
As an aside, I also wonder if we are losing sight of the original concept of a lightweight trailer if we are carrying around that much extra gear?
77 Trillium 4500
09-13-2018, 04:49 AM
Jason, your frame extension will certainly make backing up easier with the longer ball to axle distance for jackknifing. I'd take a 40+' trailer any day for backing and spotting within inches. Let us know how it works out for you.
09-17-2018, 10:06 AM
Kommander,
We have 2 trillium s and we are leaving tho other one at the stock length. This one is going to be for hunting primarily but we are doing a full restoration..
We added 16" to the rear and 4 feet to the front resulting in it being approximately 18 ft long hitch to bumper.
Also we used the stock axle which was miraculously in great shape but scrapped the entire frame. Also we used much thicker wall tubing for strength.
09-17-2018, 10:08 AM
It backs up like a dream, you could thread a needle with it, lol.
09-17-2018, 10:10 AM
For hunting it will be great, also for fishing., like I said I have 2 and the other is for trips and camping and such. It's not all that much heavier however but the tongue weight is a bit higher and it tows like a dream.
As for the frame it cost approx $900 in materials and $400 in labour. But the cost is not the issue but making it useable for what we need it for.
