Temporarily removing upper kitchen cabinet Trillium 1300 - Fiberglass RV
Old 09-04-2018, 11:55 AM   #1
Trailer: Trillium
Has anyone removed the upper kitchen cabinet from a Trillium 1300? The "backsplash" of my 1976 has some funky stuff between it and the wall and I'd like to remove it.
Randy J. is offline   Reply With Quote
Old 09-07-2018, 07:13 PM   #2
David Tilston's Avatar
The cabinets are glassed to the shell. It will be difficult to remove them intact, and not damage the shell. If all you want to do is clean behind the back splash, you are probably better off removing the ensolite inside the upper cabinet and using a long scrub brush. The water will drain out the hole the wire goes through.
Please document your progress.
May the Force be with you.
trillium, vin
Upper Kitchen Cabinet Support Length Str8781 Problem Solving | Owners Helping Owners 0 02-18-2014 10:39 AM
Sigh . . . Five Scamp Upper Kitchen Cabinet Doors peterh Modifications, Alterations and Updates 30 03-11-2011 06:19 PM
Organizer for upper kitchen cabinet peterh Modifications, Alterations and Updates 22 11-04-2008 04:55 PM
