Bigfoot plumbing vents - Fiberglass RV
Old 06-09-2003, 06:21 PM   #1
The caps that that cover my plumbing vents are pretty beat up, but I have had no joy in trying to replace them.
<img src=http://www.fiberglassrv.com/board/uploads/3ee5254c53738Temp.jpg/>
I bought one of the above vents, which look a lot like the original, but it has no where near the flexibility to curve round the corner where the vent cover must be placed.
I visited the Bigfoot homepage and certainly don't have anything that looks like a parts department. I also suspect they didn't make them this way for long because they have 16 screws in them, and are really hard on the fiberglass.
Anyone have any ideas?
Thanks :wave
Legacy Posts is offline   Reply With Quote
Old 06-09-2003, 09:30 PM   #2
I just went out and had a look at my vent cap. Your trailer must have it
in a different location. Mine sits flat on the roof, has 8 screws holding
it down, and looks very similar to your illustration. It sounds as though
yours must be on the edge of the roof.
I don't know how practical it would be, but the rubber seals for use around
residential pluming stacks are pretty flexible (although I don't remember
seeing one with a cap). My father-in-law once patched his roof vent with,
what else, fibreglass. You might be able to use it to custom form a vent
or a collar for your new vent if you can't find a suitable one available.
I notice in checking out my own vent that it is in need of some platicote
around the bottom to seal it, so I thank you for your question.:reyes
Old 06-09-2003, 09:37 PM   #3
Hi
I changed my vent caps on my boler and i went to metal.They bend to contour so worked for me.
Old 06-09-2003, 09:59 PM   #4
Orginally posted by Rock MacRae
That's what I'm thinking. I'm also wondering if I can turn the black 2" pipe that's the actual stack into one of these:
<img src=http://www.fiberglassrv.com/board/uploads/3ee557d890f6fTemp.jpg/>
by just bracing it at the base and adding a Tee to the top.
Old 06-09-2003, 10:03 PM   #5
Orginally posted by Chester Taje
The metal ones at the RV store woudn't do it, but I didn't look at Home Depot's wares yet. That might be a possibility.
Old 06-11-2003, 10:24 PM   #6
Hi,
How about using a heat gun to create the flexibility you need (without melting it, of course)
Old 06-12-2003, 04:35 AM   #7
Plastic
Soak it in hot water for a few minutes and you will be able to form it to whatever shape you want.
Old 06-12-2003, 12:45 PM   #8
Orginally posted by Ron Richardson
Hi,
Other than the fact that I am considered a menace with my heat gun, that's a good idea!
Old 06-12-2003, 12:46 PM   #9
Orginally posted by Lyndon Laney
Yeah! I think I'll try the hot water before the heat gun. Water doesn't usually get me into trouble.
Old 06-18-2003, 09:13 AM   #10
Done!
Dumping the vents in hot water worked great! I have half as many screws drilled through the vent as they put in during the original installation-- they stuck in 16!!-- and it lays down very nicely.
Thanks for the suggestion. :wave
Kitty
bigfoot
Sheesh! roof vents... Lynn L Care and Feeding of Molded Fiberglass Trailers 7 07-13-2008 08:56 PM
Covering Vents? Gerry Problem Solving | Owners Helping Owners 2 10-25-2006 11:59 AM
A/C vs. Fantastic Vents.. Legacy Posts General Chat 6 06-12-2003 02:55 PM
Leaky Windows and Vents Legacy Posts Problem Solving | Owners Helping Owners 5 04-22-2003 03:24 PM
Leaky Vents Legacy Posts Problem Solving | Owners Helping Owners 9 04-12-2003 12:13 PM
