I did it! 87 uhaul ct-13 - Page 8 - Fiberglass RV
Old 05-14-2014, 05:55 PM   #141
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
More
tartosuc is offline   Reply With Quote
Old 05-17-2014, 05:18 PM   #142
tartosuc's Avatar
Quebec
Work of the day,
Install my 90w solar panel as a rear rockguard/ rain diverter..
Tought i would do it in two hours,..took me the whole day!
Old 05-17-2014, 05:19 PM   #143
tartosuc's Avatar
Quebec
More
Old 05-17-2014, 05:21 PM   #144
tartosuc's Avatar
Quebec
Again
Old 05-17-2014, 05:24 PM   #145
tartosuc's Avatar
Quebec
Detail of the installation
Panel is about 15 lbs, Panel framing is very sturdy so i attached directly to it.
I used a regular piano hinge with sheet metal screw into the panel framing. On the camper side i used 4 x 1/4" bolts with nuts. Two closer to the center and one at each end. The two in the middle have a bar in between them inside the camper to spread the load. I had to use thick nylon spacers for the ones at the ends as the camper is rounded ... Behind the hinge is a lot of butyl tape and marine/rv silicone, over the hinge i placed some double sided tape and a biycle tube splitted in half over the tape that will stop water from going trough the hinge.... For the wires, i simply used the belly band as an attachement point with zip ties, drilling trough the belly band( its over an inch ) wires run down following the band and go into the camper via an old drain hole under it.
Old 06-25-2014, 05:02 PM   #146
Trailer: Burro 13'. 1982
Montana
Tartosuc,
Do you have any plans to put up a backsplash? If so.....please share! I have the same curves on my wall that you do. I've got a 1982 Burro. I love your mods!
Lfoxmont is offline   Reply With Quote
Old 06-25-2014, 07:49 PM   #147
tartosuc's Avatar
Quebec
Originally Posted by Lfoxmont View Post
Tartosuc,
Thanks for the kind words.
We tought about a backsplash but find most of the solutions very expensive(got things to fix in the house that are more urgent) . Since we dont cook much inside, we will probably leave it as it is. I'm thinking of making a piece of wood over the stove that would be attach with an hinge at the back, when flipped down it becomes counter space, when flipped up it's a backsplash...
Old 06-26-2014, 08:36 AM   #148
D Davis's Avatar
Virginia
Bernard, good thinking. I like that idea! I do not choose to cook inside my camper either. With the bear problem where I live, the camper would be "Can Tuna" for them.
Old 06-26-2014, 02:45 PM   #149
Montana
I haven't cooked in my Burro either, I just like the idea of covering a lot of little holes made by POs. And I like the backsplash that Pam (I think it was Pam) did. Those wavy parts of the wall are discouraging.
Old 06-30-2014, 01:24 PM   #150
tartosuc's Avatar
Quebec
Woke up sunday am with no specific plans in mind for my day, so i decided to build a table to hold my two burner stove.
I made it using an old bicycle rack and some sçrap metal pieces i had aroud...total cost 5$ for a u-bolt.
Old 10-06-2014, 09:13 AM   #151
tartosuc's Avatar
Quebec
HI all,
season is coming to an end, I did not use the trailer as much as I would like to, but that life...next year will be better.
I was thinkering about future mods, and the main thing that bugs me and my wife is the bed size.
Since we don't use much of the kitchen anyways, I was thinking of removing the sink area and half of the entrance cabinet to extend the bed a good 12''
I could fit a very very tiny sink/faucet, good enough for brushing teeths at night...
comment ? ideas?
Old 10-13-2014, 07:24 AM   #152
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
Georgia
Someone did a mod to extend the bed between the cabinets. Don't remember who. I recall it would slide out from under the bed and then retract when not in use.
--Sean
1984 Uhaul CT 13
TV: 2007 GMC Acadia SLT-2, 2001 Mazda Tribute V6
My U-haul Camper Blog
--Sean
1984 Uhaul CT 13
TV: 2015 GMC Acadia V6, 2008 Jeep Wrangler Rubicon, 2001 Mazda Tribute V6
knighth001 is offline   Reply With Quote
Old 10-13-2014, 08:21 AM   #153
Timber Wolf's Avatar
North Florida
I gave some thought to widening the bed in my Scamp but decided it was too much trouble. I am going to try one of the "T" shaped bed extension mods and see how that sleeps. If that does not work I will just limp along until retirement when I can get that new Escape or Oliver. Love your window shade solar panel!
uhaul
PA: UHaul CT 13 Thomas G. Referrals: Molded Fiberglass Trailers 5 05-10-2013 11:52 AM
TX: UHaul Thomas G. Referrals: Molded Fiberglass Trailers 1 04-23-2013 09:43 PM
UT: UHaul 13' Thomas G. Referrals: Molded Fiberglass Trailers 0 04-14-2013 01:34 PM
uhaul Maggie Problem Solving | Owners Helping Owners 11 09-27-2006 08:34 PM
UHaul 13'er Lance M C Problem Solving | Owners Helping Owners 9 08-12-2006 11:36 PM
