1971 Trillium Window Removal - Fiberglass RV
Old 08-20-2016, 02:15 PM   #1
Trailer: 1971 Trillium 13ft
Hello
My wife and I have purchased a 13ft 1971 Trillium. We would like to remove the front and rear windows. Can anyone provide us with direction/pictures/video on how to remove the rubber seals and windows?? We are totally new to this and don't know where to start. Any help would be appreciated.
wdmd is offline   Reply With Quote
Old 08-22-2016, 01:51 PM   #2
David Tilston's Avatar
The windows on a Trillium use rubber seals in the construction of the window, but the window is installed using butyl tape, not rubber. To remove the windows, pull off the plastic screw covers, remove the screws, they may be quite rusted. Pull the windows out from the bottom. They kind of hook in at the top. Clean the old butyl tape off both the windows, and the shell of the trailer. Inspect the wood that he the windows screw into. If it is dry and solid, then leave it. If wet and rotten, then carefully peel the ensolite away from the wood. Try to not damage the black ensolite foam. I have found it much easier to remove rotten wood then wood that is in good shape.
New butyl tape is available at the parts department of your local RV dealer. Line the flange on the window with new tape. Reinstall the window, top first. Use new screws. I would use stainless screws and nylon washers to limit corrosion as the result dissimilar metals.
trillium
Trillium Window Removal David Swinnard Problem Solving | Owners Helping Owners 77 09-05-2016 07:25 PM
Trillium window removal drdoyle Problem Solving | Owners Helping Owners 15 07-11-2015 04:34 AM
Trillium 1300 Jalousie window removal krg Problem Solving | Owners Helping Owners 3 07-29-2013 09:22 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
1971 Trillium Rear Window Cracked...help me... Paul Richter Problem Solving | Owners Helping Owners 8 08-11-2009 05:35 PM
