Boler side marker lamps-LED - Fiberglass RV
Old 09-24-2017, 06:56 PM   #1
Trailer: Trillium 1979 13ft.
Just wondering if there is a direct replacement LED bulb that I can swap out with my stock old-school light bulbs. Does a direct replacement exist??
Butsky is offline   Reply With Quote
Old 09-25-2017, 03:11 AM   #2
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Yes they do. I had a bunch of T10 base LED's sitting at home and I used them all for the front markers. I had Bargman bullseye markets for the rear so I ordered a bunch off ebay in red and bought a bunch of clear lenses as well.
Look at this on eBay http://www.ebay.ca/itm/171145792642
The lenses were bought through Lordco but any truck supply would have them as well.
If you're patient use ebay otherwise seek out a local LED supplier.
ststefan is offline   Reply With Quote
Old 09-25-2017, 06:05 AM   #3
Led replacements
Thanks but my original bulbs are the old style center contact with two "lugs" that stick out and lock in socket when rotated...
Old 09-25-2017, 06:52 AM   #4
ststefan's Avatar
Maple Ridge, B.C.
If you find a number or base number you still probably find them on ebay or a local LED supplier.
Old 09-25-2017, 08:12 AM   #5
ststefan's Avatar
Maple Ridge, B.C.
Pull a bulb and go to your nearest auto parts store and match up the bulb if you cant find a number on the bulb. That will gine you a starting point for replacing with LED lights. I did that at Canadian tire to replace my license plate bulb on my Boler. All the 1156 base bulbs I has were too long and I found the replacement number and then ordered it in LED.
Old 09-25-2017, 09:36 AM   #6
Carl V's Avatar
Your marker lights probably have a BA9S base.
I put these on my Trillium:
https://www.amazon.ca/gp/product/B0183LOZ2Q
https://www.amazon.ca/gp/product/B0183LOZ5S
Old 10-01-2017, 05:53 PM   #7
led
Deals extream has loads of that stuff takes about 10 or so days way cheaper than an rv shop. they to shop at the same place about $7.00 cdn for2 or $20.00 from the rv shop
boler
Replaced Lamps with LED's TomK Electrical | Charging, Systems, Solar and Generators 12 08-18-2014 02:05 PM
Dual mode LED blinker side marker lights GregLS Electrical | Charging, Systems, Solar and Generators 4 06-09-2014 03:23 PM
Boler 1700 Side Marker Lights timmckee Modifications, Alterations and Updates 6 08-15-2011 01:57 PM
New Lamps for Old, New Lamps for Old! bfrq25 General Chat 6 04-03-2011 04:57 PM
Dot-It LED lamps Rick B Modifications, Alterations and Updates 24 02-03-2008 04:25 PM
