Originally Posted by Stephen_Albers
If your Dometic has not been used in years I can think of at least 4 components that are time-replaceable that will need to be changed for reliable operation. Dometic makes a very fine product. Mine has made ice in 6 hours on propane for many years. But they often fail because they are installed incorrectly and improperly serviced. Caveat Emptor
Please do detail the four components that you refer to.
I have several RM211's and RM36's, and one RM24. Some have sat for several years unused and unmaintained. When plugged in, and level, they freeze water.
Since a major failure of the cooling system is frequently caused by corrosion of the heated section. I can't see running them continuously being very good for them.
There are many examples of absorption fridges that are on the order of 40 years old that work fine. I see RM211's on kijiji regularly.
Mensi, Since you are in Alberta, if you can't get yours working, then maybe take a look at this one:
https://www.kijiji.ca/v-trailer-part...ationFlag=true
