Replacing 1972 Boler plywood sheet floor? - Fiberglass RV
Old 06-05-2018, 04:56 PM   #1
Hi everyone. I’m new to this sight, and a very new Boler owner. The existing plywood floor in my Boler is punky and soft and needs to be replaced. The outside top edge of the floor is fiberglassed about 4 inches in from the walls on the plywood surface. Should I cut the fibreglass back to the wall or should I delaminate the fibreglass from the wood floor surface some how. 🌺
Sandy overman is offline   Reply With Quote
Old 06-06-2018, 09:19 AM   #2
Jon in AZ's Avatar
Cut back, replace the plywood, and re-glass the perimeter. Do it in sections to maintain shell support.
Old 06-06-2018, 09:27 AM   #3
Thank You
That’s exactly what I needed to know
Old 06-09-2018, 02:32 PM   #4
Roy in TO's Avatar
I would not cut it back all the way to the wall. Leaving some will give you a tab to know where the floor belongs when you replace the wood.
Make your floor templates before you start cutting.
boler
Sheet of plywood as finished floor? DIY parquet? Zennifer Modifications, Alterations and Updates 30 01-07-2016 10:28 AM
Replacing plywood Celeste Problem Solving | Owners Helping Owners 2 05-05-2012 02:25 PM
Plywood floor replacement supplies Mike Shackelford Problem Solving | Owners Helping Owners 3 10-08-2009 07:17 PM
Floor replacement Options - OSB vs Plywood. Oliver P Problem Solving | Owners Helping Owners 11 08-11-2009 08:34 PM
Plywood Floor Replacement 72 Boler Annie T Problem Solving | Owners Helping Owners 5 07-24-2007 10:19 PM
