Mold and Mildew removal Trillium - Fiberglass RV
Old 02-17-2013, 08:18 PM   #1
Name: Kurt and Heidi Siens
Trailer: 1975 Trillium 1300
Ohio
First time camper owners and we need advice....How do I remove mold and mildew from the outside of my camper? Will cleaning products (bleach, degreaser, etc) damage the fiberglass? Can I use a pressure washer?
heidifella1 is offline   Reply With Quote
Old 02-17-2013, 08:30 PM   #2
Carol H's Avatar
I wouldnt use a pressure washer as it could etch & damage the fiberglass gelcoat. I good wash using a micro fiber cloth spong. Some folks swear by Mr. Clean Magic Eraser to get the worst off. To finish it up and take the stubborn stuff off you could try the product - its great at taking of black streaks & caulky finish off and gives you a shine. Use a power buffer with a wool bonnet to get it done fast or use a microfiber cloth to put it on and take it off.
Old 02-17-2013, 09:05 PM   #3
I use a house siding cleaner, Jo-max mixed with bleach. Use a deck sprayer to apply and let it set about 15 min. and wash it off with a rag or brush. Rinse and reapply to spots if needed. Then rinse the trailer really good and let it dry in the sun and it will brighten up.
Eddie
Old 02-17-2013, 11:58 PM   #4
Perry J's Avatar
Send a message via AIM to Perry J Send a message via Yahoo to Perry J
I use plain old 20 Mule Team Boraxo like you use in the laundry.
I wet an area down, sprinkle the Boraxo on and use the rough side of a scrubby sponge.
It is slightly abrasive and will also remove most of the chalk on the surface and make waxing much easier.
John
Perry J is offline   Reply With Quote
Old 02-18-2013, 06:49 AM   #5
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
I do most of my cleaning this way:
1)wash with a good qualty soap and a stiff nylon bristle brush.
2) hose off
3) use nu-finish and lots of elbow grease
Joe
Old 02-18-2013, 08:47 AM   #6
Trailer: Trillium 13 ft (green grape)
VIM bathroom and kitchen cleaner is great for cleaning the older trailer. After a good wash and rinse let dry well. Then apply ZEP wet look floor finish. You'll need about 5 coats but if you start at one end the other ends dry and you just keep going. It only takes about 10 mion to do a coat but "BOY WHAT A SHINE". This product is like weater and you just wet the appying cloth and half wring out and wipe it on.
Ron
RRJR is offline   Reply With Quote
Old 02-18-2013, 10:29 AM   #7
Trailer: 2010 Scamp 16
You can use a power washer. Just need to have the spray in a fairly wide fan and avoid the temptation to go really close trying to get stubborn spots off. Coin car wash is one option to get the worst of the gunk off. It's been done several times to my trailer without problems.
Important to rinse before scrubbing, you don't want to rub dirt with you cleaning brush or rag, it leaves scratches (think sand paper).
I used a scrub brush with a handle and trisodium phosphate (tsp) available at big box home improvement or paint stores. Good general cleaner that rinses well and leaves no residue.
Barkeepers Friend (BKF) a powdered bleach that is mildly abrasive (really mild) applied with a wet rag or scrub brush. Think super mild Comet.
Green pot scrubbing pads (3M) be aware that if you bear really hard on them in a small area of fiberglass they can leave scratches, there is a less abrasive pad, I think it is white.
Green scub pad and BKF worked well on aluminum to clean as prep for polishing with Semi-Chrome (online or auto parts store, may have to order) or Nev R Dull. Be aware that aluminum polish creates a black "haze" that will get on your fiberglass if you don't use something like masking tape to protect the fiberglass. Key thing some aluminum polishes leave a protective film, some don't.
Auto Detail scrub brushes available at auto or big box retailers. Think big, stiff tooth brush for nooks and crannies.
Mine looked pretty much like yours when I got it, started with power wash rinse, followed by scrub brush and BKF, followed by rag, scrub brush or scrubbing pad with BKF on stubborn spots. Followed by wash with TSP.
Polished aluminum, rinsed and applied RedMax Pro floor wax there is a whole thread on that subject with pros and cons of these types of wax on fiberglass campers.
I like cleaning, it makes a huge, highly visible improvement :-) Don't forget to post "After" pictures.
Results (yes those are tree reflections on back left edge of roof):
Old 02-18-2013, 12:40 PM   #8
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
My favorite cleaning solution for this kind of thing is a bucket of hot water with powdered dishwashing detergent and a dash of bleach. It will cut right through that mold/dirt/mildew and won't hurt the gelcoat.
Use rags or a sponge- a string mop is handy for the top- and rinse well. Done!
Francesca
Old 02-18-2013, 01:21 PM   #9
alan in alberta's Avatar
Trailer: 2006 Escape 17 B Raven and a Pearl
remover
i have had good success with tilex mold and mildew remover.
put it on wait and while for it to penetrate and rub off with a softcloth
rinse well
alan in alberta is offline   Reply With Quote
Old 02-19-2013, 09:45 AM   #10
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
rinse well
YEP! Works well for cleaning mold/mildew off the older model FGRVs with the 'elephant skin' interiors too. Just make sure you have plenty of ventilation. That stuff is STRONG...
Harvey is offline   Reply With Quote
Old 02-19-2013, 09:51 AM   #11
I think that the active ingredient in Tilex's (and others) mold-and-mildew product is bleach, which is why it's effective to kill mold and mildew.
Bleach has no equal in that department, and a cleaning solution as effective as Tilex can easily be made by adding household bleach to a cleaning solution.
Do not add to ammonia solutions, of course!
Francesca
Old 03-05-2013, 07:17 PM   #12
Trailer: 1977 Trillium "Trilly"
Nova Scotia
Success cleaning ours with a ton of muscle power and about 8 Mr. Clean magic erasers. Inside cleaning on that elephant skin done with another ton of muscle power, a 2-inch potato scrubby brush and Tilex (wear safety goggles so when you look up to clean the ceiling you don't have Tilex sprayed in your eyes!). The textured skin was horribly dirty and the only thing I could come up with was the small, stiff brush. Rags did nothing. Alot of hard work, but great results. And not a really terrible thing to do on a warm, sunny day!
rapunzellle is offline   Reply With Quote
Old 04-09-2015, 08:49 PM   #13
Trailer: Trillium
I know this is an old thread but. ..
I'm wondering if it's okay to use a gloss over the ghosting left from mold mildew. ....or does that ghosting mean it's really not clean yet? I've been working hard to get the black spots off, but they've been there awhile I think and even after scrubbing and rinsing there's still a faint image of the spots left. Looks a lot better but I don't want to seal it up if it can get even cleaner. Suggestions? Thanks.
Nightwing is offline   Reply With Quote
Old 04-09-2015, 11:31 PM   #14
Carol H's Avatar
You should be able to buff the ghosting out.
Have you tried using any of the 3M Marine products to remove it yet? The 3M Restorer and Wax is probable all you need. Its $19 a bottle and bottle will do the whole trailer. If that doesnt work one of their slightly heavier compounds will.
Old 04-10-2015, 04:03 PM   #15
Trailer: Trillium
I decided I'd better clean it up a bit more first to help keep it from growing back. So I got some mold mildew remover and used that. Wow! I wish I'd used that yesterday. It's looking BEAUTIFUL! 😊 I just need to climb up there and get around the vents now, which are still extremely black. Ugh. I got some marine polish and wax too, but I'm thinking I won't need the polish after this it's looking so good. I'm SO happy!! Thanks for your help!
Old 04-23-2015, 12:12 AM   #16
Trailer: 1985 BigFoot G
Mississippi
This is the before and after pix of mine. I am STILL working on the outside of it so I'm not done yet. Also tires will be replaced they are dry rotted needless to say. It sit under a tree for 4 years that we know of. It's taken us a few weeks just to get the stuff growing on it off and then the stuff under that off. LOTS of elbow grease as my Gma used to say.
I started out with just a scrub brush and dawn dishwashing liquid. It had old moss that grows on trees growing on it in layers. We had to get the top layer off before we could get to the bottom layer of it. Then someone told me about Clorox cleaner so I tried that since I had some and it worked wonnnnderful. I'd spray it and let it sit and then scrub and rinse well. I just ordered some protect all oxidation remover and color restorer to put on her next. We're going to take the windows out and reseal all of them with the butyl tape and all of anything that is coming through the camper will be resealed and fixed so there will be no leaks. A project but we're going to do it if our health will hold out.
Gardnpondr is offline   Reply With Quote
Old 04-24-2015, 09:03 PM   #17
Trailer: TBA
Wisconsin
Looks great Gardnpondr.
Badger is offline   Reply With Quote
Old 04-24-2015, 10:48 PM   #18
Mississippi
Thanx
Old 04-25-2015, 10:13 AM   #19
Denece's Avatar
Trailer: Compact II
One other thought for mildew remover is Oxy-Clean. It does a great job and no stink or residue. I have been amazed at what you can clean up with this stuff!
Denece is offline   Reply With Quote
trillium
Mold, Mildew, and old foam Bill K Jr Care and Feeding of Molded Fiberglass Trailers 7 04-09-2012 05:42 AM
Need Help with Carpet Removal on Trillium Jola & Liz S Care and Feeding of Molded Fiberglass Trailers 4 06-21-2009 01:17 PM
Black mold & mildew jrnutpaul Care and Feeding of Molded Fiberglass Trailers 4 09-26-2008 12:27 PM
Cleaning mold/mildew Rick and Shannen Care and Feeding of Molded Fiberglass Trailers 7 02-27-2006 10:31 PM
Cleaning mold/mildew General Chat 0 01-01-1970 12:00 AM
