Sk (Canada) - 1977 - Trillium 4500 - $2000 - Fiberglass RV
Go Back   Fiberglass RV > Marketplace > Referrals: Molded Fiberglass Trailers
Old 07-09-2014, 03:04 PM   #1
David Tilston's Avatar
Not a Deluxe, No window in door, no shelves front or back, it has DC lights, so it probably has a converter.
The damage seems minimal. Probably has a small tear in the fibreglass. Were I in a buying state of mind, I would be in my tow vehicle heading there now. Since he has been trying to sell it since June 2, I suspect that he would go lower then $2000.
1977 Trillium | travel trailers, campers | Saskatoon | Kijiji
Date Listed 02-Jun-14
Price $2,000.00
Address Saskatoon, SK S7K 6P8
View map
For Sale By Owner
Colour Other
Year 1977
REDUCED!!... $2000.00...Cleaned inside and out in the last week ready for Craven if u like... Some damage in front due to fallen tree...sitting at Tobin Lake, Prudens Pt. Awning in awesome condition, mirrors and and extra goodies!! Awning cleaned today - nice little unit....has done the Craven extravanganza once!! Not enough!! I realize location of bowler not ideal but would be totally worth your while checking it out...great little unit!! It can be yours!!
Old 07-09-2014, 05:57 PM   #2
Trailer: Trillium 13 ft (green grape)
This will go quick, great price even tho it needs a little work,
RRJR is offline   Reply With Quote
Old 07-23-2014, 09:33 AM   #3
Trailer: Trillium
Saskatchewan
I'm heading up Sunday to get a better look at this, Planning on bringing new tires on rims, tools to pack the bearings and magnetic lights for the ride home.
dbir is offline   Reply With Quote
Old 07-23-2014, 11:26 AM   #4
Good, cause if it sat on kijiji much longer, I would have made an offer.
Old 07-23-2014, 11:28 AM   #5
Trailer: Trillium
Saskatchewan
It started as a much higher price and has been reduced, the owner is a co-worker with my wife. It hasn't moved in over 10 years, so i have my concerns over if its roadworthy, but will get it sorted.
Old 07-23-2014, 11:32 AM   #6
Please post pictures, and a serial number.
Old 07-28-2014, 10:11 AM   #7
Trailer: Trillium
Saskatchewan
As planned i made a run up to Tobin lake Sunday.
Took me about an hour to pull the hubs, repack the bearings, and swap the wheels/tires to make it tow able. Pulled nicely, the Jetta had no complaints about sitting at 110 on cruise.
Old 07-28-2014, 10:50 AM   #8
Nice! Have you pulled of the tuck tape yet?
Old 07-29-2014, 04:14 PM   #9
Trailer: Trillium
Saskatchewan
The tape has been removed, the damage is larger than i was expecting, but should be pretty straight forward to fix. It extends from the hump on the raised ceiling in front of the vent to just over the corner. I've got it ground out now, prepped, and the first layer of glass in place. Intentions for tonight are to put a few hours in building more layers of fiberglass to complete that part of the repair. The only snag was that i had to remove the awning mount so i could grind out far enough to fix the crack properly.
Old 07-29-2014, 04:35 PM   #10
Umm.... Pictures?
Old 07-30-2014, 08:31 AM   #11
Trailer: Trillium
Saskatchewan
I didn't really think to take many, was more concerned with getting it done so i can get the space back in my garage.
Here is a shot of where i left off last night, its nice and solid now, few more strips to lay, and then can start trying to make it look pretty. Also replaced all the broken/missing side marker lights, and put a set of LED tail light bulbs in, installed another new tire/rim for the spare, and the GF scrubbed the interior twice, smells nice and clean now!
Old 07-30-2014, 11:17 AM   #12
That is bigger then it looked in the pictures.
Old 07-31-2014, 08:49 AM   #13
Trailer: Trillium
Saskatchewan
6 layers of glass, and the first skim coat of body filler are on now, some more sanding and skimming and i'll be onto primer before the weekend.
Old 08-01-2014, 08:49 AM   #14
Trailer: Trillium
Saskatchewan
Few more minor touchups to do, and a coat of paint, but the roof portion is done. Interior is gutted, goal for the weekend is to paint the inside, paint the doors, and get started on re-covering the cushions in denim, and replacing the flooring. Have a company camping trip in 2 weeks that i want this thing ready for.
Old 08-05-2014, 03:07 PM   #15
Trailer: Trillium
Saskatchewan
Need to knock the gloss off, but i'm happy with the roof
Masked the interior this weekend and began spraying, semigloss white, have 2 complete coats on now, one more and i can unmask/take pictures. It looks much brighter/cleaner. New T molding has been ordered, and the cushions are being recovered in denim, new blue curtains are being made up, and the drawers/cabinets/table will be painted as well. On track to take it for the first camping trip the weekend after this one.
Old 08-05-2014, 04:03 PM   #16
Cathi's Avatar
POBox 1267, Denison, Texas
Looks gorgeous. What a great job.
Cathi is offline   Reply With Quote
Old 08-05-2014, 05:04 PM   #17
I am impressed. Maybe try giving it a good scrub, then Zep wet look. Might even out the shine.
Old 08-06-2014, 10:22 AM   #18
Trailer: Trillium
Saskatchewan
Some quick shots of the interior, will do another coat before i call it good, but looks much cleaner! I'm using a high end acrylic enamel interior paint as was suggested in another thread, its semi gloss finish, and i left it untinted in pure white. I thinned it approximately 10% and sprayed through an automotive HVLP gun with a 2.4mm tip (high build primer gun) The storage areas front and back are now coated with a rubberized rocker guard to make cleaning them up a little easier.
Old 08-06-2014, 02:34 PM   #19
Trailer: Trillium
Saskatchewan
Moving this thread over to a new home to track the continued work http://www.fiberglassrv.com/forums/f...air-65666.html
trillium
On (Canada) - 1979 - Trillium Sportsman - $2000 David Tilston Referrals: Molded Fiberglass Trailers 12 10-07-2014 03:08 PM
AB (Canada) - 1977 - Trillium 1300 - $2000 David Tilston Referrals: Molded Fiberglass Trailers 0 06-24-2014 01:46 PM
AB (Canada) - Trillium 4500 - 1978 - $4500 David Tilston Referrals: Molded Fiberglass Trailers 16 04-22-2013 01:07 PM
AB (Canada) - 1973? - Trillium 1300 - $2000 David Tilston Referrals: Molded Fiberglass Trailers 4 03-05-2013 03:18 PM
CANADA - 1979 - Trillium 4500 - $2000 David Tilston Referrals: Molded Fiberglass Trailers 1 07-17-2012 01:33 PM
