Trillium 1300 DC Overload Block Malfunction - Fiberglass RV
Old 08-18-2014, 11:18 PM   #1
Trailer: Trillium Outback 2004
3 hours with an electrician and we narrowed the 12V problems down to a malfunctioning DC overload block. It's between the 12V batteries (in feed) and the fuse panel.
Two questions -
How to get access to the block for removal? The water tank is in the way.
Where to get a new block?
We were wondering if the water tank is in backwards since there is a drop down section on one side of the tank that would make access to the wiring much easier, but it is on the side facing the outside of the trailer.
It's so tight I can't even get a photo of the block!
Any help or ideas much appreciated.
BarbinBC is offline   Reply With Quote
Old 08-19-2014, 07:02 AM   #2
Roy in TO's Avatar
Try contacting Trillium Outback. They are still in business.
Old 08-19-2014, 07:22 AM   #3
Bob Miller's Avatar
Trailer: Class A Motorhome
What the heck is a "DC Overload Block"? I've never heard that term used when referring to RV wiring.
BTW: What was the original problem?
Old 08-19-2014, 09:21 AM   #4
Carol H's Avatar
Depending where in BC you are Escape Trailers in Chilliwack have a lot of experience with Trillium's (in fact built them for Trillium for a time). They do repairs on all brands of fiberglass trailers and their rates are hard to bet here in BC.
I am also confused as to the terms used in the original post so not clear on the actual issue....
Old 08-19-2014, 11:44 AM   #5
Trailer: 2010 Scamp 16
Are you talking about something like this overload relay?
How the overload relay ('thermal block') protects your air compressor - Air Compressor Guide
Or is it something that just holds fuses. Those come in blocks but it would seem a most odd spot for a fuse block.
Old 08-19-2014, 12:08 PM   #6
Carol H's Avatar
Its a head scratcher but I would have thought that there was just a simple inline fuse between the battery and fuse panel which is what most trailers have. As it was suggested earlier I suspect calling Trillium in Calgary who built the trailer may result in a good answer to the original question.
Old 08-19-2014, 03:17 PM   #7
Trillium DC Overload Block
Thanks for your responses. To answer some of your questions:
The 12V system was working when I left on holiday but not after that. We checked the batteries, fuses and all were okay so we went back further.
Where the power from the 12V batteries comes through the front wall of the trailer and is attached to a "block" by 2 screws with 2 wires under each screw on the block.
My electrician says this block is to prevent any overload/excess power coming into the trailer. The block itself is attached to the front wall of the trailer and is a piece of black plastic, rectangular shape, about 1" x 3/4" by 3/4" thick.
Everything was checked with a multi-meter and that's where he found the short.
trillium
Electric brake malfunction Kenny Strong Problem Solving | Owners Helping Owners 4 08-07-2013 04:29 PM
Generator problem: Overload light Dale Peters Problem Solving | Owners Helping Owners 3 06-19-2008 11:39 PM
Have you noticed more RVs on your block? Gina D. General Chat 3 06-08-2008 07:42 PM
Circuit Breaker overload? TorreyT Problem Solving | Owners Helping Owners 10 05-20-2007 02:33 PM
