Boler interior cabinet paint. - Fiberglass RV
Old 05-07-2017, 09:37 AM   #1
Trailer: Boler 1973
Hi there, I'm wondering if anyone could provide a bit of feedback on painting my interior fiberglass cabinets and storage. One of the previous owners of the Boler I recently bought put a lot of screw holes in all the fiberglass storage and cabinets. I've sanded and filled everything but am a little hesitant to start painting. I was thinking of putting a primer and a couple topcoats of a rustoleum product on everything (except the Ensolite, it is actually pretty clean) but want to make sure that It adheres well. Any advice?
A_Generalist is offline   Reply With Quote
Old 05-07-2017, 10:15 AM   #2
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Hey Sean, I would get some grease and wax remover from a paint supplier and
clean the panels apply primer and sand to at least 320 or finer clean with tack rags and should be good to go!!
Fred
Old 05-07-2017, 12:10 PM   #3
Trailer: Boler 1973
Thanks! Sounds like I am on the right track. Just getting started on fixing up our Boler, thought we would get the cabinet painting out of the way early on.
Old 05-08-2017, 10:23 AM   #4
Kai in Seattle's Avatar
We'd use, after proper prep as suggested above, Rustoleum Marine primer in white and Rustoleum Marine enamel. It makes a very nice surface. It adheres very well.
There are better Marine enamels, but Rustoleum does a very fine job. And for inside--? We used it on the outside AND inside, and it came out really nice.
BEST
Kai
Semper ubi sub ubi.
Old 05-09-2017, 10:48 PM   #5
Trailer: Boler 1973
Thanks! This is great, I'll share my before after pictures. This Boler interior felt a little like Swiss cheese... glad to be taking back to hopefully what it originally looked like
Old 12-15-2019, 05:14 PM   #6
"There are better Marine enamels, but Rustoleum does a very fine job. And for inside--? We used it on the outside AND inside, and it came out really nice."
How has this been holding up
Johnb533 is offline   Reply With Quote
Old 12-15-2019, 06:44 PM   #7
Johnb533: it's holding up excellently since early 2016. We don't cover it and we don't store it inside. We DO check it about weekly for leaks. It was a leaking water tank and toilet drain that seemed to be the focus of the trouble to begin with--that and some small cracks above the door that let the door frame rot out. THAT was rebuilt with very sappy local fir that we read was pretty good at resisting occasional water. We did reseal everything after fixing/fiberglassing over 82 holes. Paul is a tireless prepper and sander and refinisher.
The paint is doing great. I know there is at least one better marine brand, Briteside or Brightside. But we "found" this, and finding is 9/10ths of gettin' 'er done. And DONE is better than "perfect." At least, sez me.
BEST
"K"
Semper ubi sub ubi.
Old 12-15-2019, 10:31 PM   #8
That's great to hear we are starting to think of paint in the near future it's good to know it has been holding up good! How did you paint yours? Roll and tip?
Old 12-16-2019, 03:35 PM   #9
Paul used a foam "hot dog" roller and nothing else. He rolled it THIN and diligently after leaving weird brush strokes by trying to "tip" it. The point of the tipping is to make sure all the bubbles are broken; the marine enamels self-level very nicely, but those pesky bubbles...as it was, between thinness and serious rolling, he broke all the bubbles with the roller itself. He didn't u se a fuzzy roller. Then he sanded between coats and rolled again. He used 1-2 layers of primer, sanding between, and 1-2 layers of paint, being sure to end each roll INTO the wet area. It seems to keep it all smoother.
Good luck to you! By the time you're painting, you are really on top of the project! It is so satisfying to make it pretty!
We love pics...hint hint.
BEST
"K"
Semper ubi sub ubi.
Old 12-16-2019, 03:41 PM   #10
THIS is what we covered. The white areas are primed, filled holes, mostly.The neighbors thought it was some kind of skypod or ski lift...
Semper ubi sub ubi.
Old 12-16-2019, 03:41 PM   #11
Trailer: Eco
Kansas
I just used hard-ware store rustoleum enamel rolled on after a light scuffing. They came out beautifully. I also had a *lot* of screw holes to fill.
My '71 Eco Restoration Gallery
Baxter is offline   Reply With Quote
Old 12-16-2019, 03:47 PM   #12
And this is a sample of how it looks now; we never got many pics inside, too bad. Photo System Failure.
We added a few more decals, from e-bay. You can get some customized, logos reproduced, fun things...and it makes the project look more finished.
Good luck to you!
"K"
1A 3 Setting it down again after removing it from the frame.jpg   Peanut 10 2015 to 6 2016 053.JPG
Semper ubi sub ubi.
Old 12-16-2019, 05:29 PM   #13
Rustoleum paint makes a nice product. The big mistake is to use latex, especially house paints. UGH!
Semper ubi sub ubi.
boler, paint
1973? Boler interior - paint? Remove old carpet. Help!! Chloesboler Problem Solving | Owners Helping Owners 4 07-21-2015 02:01 PM
Interior Paint--Remove or Paint Over Lora Care and Feeding of Molded Fiberglass Trailers 7 12-15-2014 11:30 PM
13' boler Kitchen cabinet paint mposehn Modifications, Alterations and Updates 0 05-20-2014 06:23 PM
