Riveting '77 Boler 17 ft - Fiberglass RV
Old 05-08-2017, 12:41 PM   #1
daveandbonscott's Avatar
Name: Dave and Bonnie
Looking for advice on size of rivets to use and how to rivet L brackets on inside
wall of trailer. Seems my throw distance on my pop rivet isn't long enough to grab so can't seem to catch rivet to "pop" it.
Also looking for spring loaded latch for rock guard on front window - I know it is the same as one on older Bigfoot trailers
Thanks for help -
Dave, Bonnie, and "Bernice"
daveandbonscott is offline   Reply With Quote
Old 05-09-2017, 07:52 PM   #2
What are you mounting on the L brackets? And I assume you mean interior of a wall that goes to the outside? If I had the option to not put a hole to the outside I would take it. We put up some small shelves and used the 3M mounting tape. A few washboard roads later they are still holding fast.
Old 05-09-2017, 07:54 PM   #3
And I wonder if this would work for the pin to hold the rock guard?
H) Spring Loaded Pull Action Pin Latch - LGM Hardware Ltd.LGM Hardware Ltd.
https://www.aliexpress.com/store/pro...143739135.html
Old 05-10-2017, 09:05 AM   #4
thanks so much for advice and suggestions
i am replacing existing rivet that held L brackets - one just to stabilize the
side wall of the oven/stove/sink cabinet and the other much large to hold the
bunk bed at front of Boler
will see if the snap ring is long enough, excited about the possibility
Old 05-10-2017, 09:40 PM   #5
Jan Dyke's Avatar
Trailer: boler
also if you are using pop rivers use Blind Rivets as they are water proof
Jan
Jan Dyke is offline   Reply With Quote
boler
There's a hole in my Boler my Boler my Boler FRED SMAILES Modifications, Alterations and Updates 250 03-03-2024 02:51 PM
Pop Riveting 77' Boler 17 footer/ Spring Loaded Catch Rock Guard daveandbonscott Problem Solving | Owners Helping Owners 1 05-09-2017 10:29 AM
