17" Bigfoot dry-rot over kitchen counter - Fiberglass RV
Old 07-11-2014, 05:33 PM   #1
Trailer: Bigfoot 17
I've got some dry-rot under the kitchen window. Removed counter and some wall paper. The plywood that's not rotted seems to be glued to the Styrofoam.
Any Ideas on how to fix???
hoppy1962 is offline   Reply With Quote
Old 07-11-2014, 06:45 PM   #2
I hope to be able to tell you in a couple of weeks my trailer was broken into this past March and the window was left open as a result the wood is soft.
We shall see whet the insurance result is.
Daniel A. is offline   Reply With Quote
Old 07-11-2014, 06:50 PM   #3
Tom Trostel's Avatar
Send a message via AIM to Tom Trostel Send a message via MSN to Tom Trostel
The entire interior of 1500 series Bigfoot trailers is made of a sandwich of exterior fiberglass, 1" styrofoam, and luan plywood. I would remove as much rotten plywood as possible without destroying too much foam then glue on a replacement material.
Tom Trostel is offline   Reply With Quote
Old 07-11-2014, 07:13 PM   #4
Trailer: Bigfoot 17
[QUOTE= I would remove as much rotten plywood as possible without destroying too much foam then glue on a replacement material.[/QUOTE]
Good Idea Tom. But my concern is lining up the new plywood perfectly with the old plywood. I wonder If I could use Drywall compound too help blend them in?
Old 07-11-2014, 08:24 PM   #5
Could you do some sort of tile behind the sink? A tile backsplash would look nice and would cover any seams in the plywood. From the photo this looks to be cosmetic rather than structural.
Old 07-11-2014, 08:38 PM   #6
Trailer: Bigfoot 17
Good Idea Jack. I think my problem is solved! Just have to think about the type of tile. (ceramic, porcelain, etc....)
Old 07-11-2014, 09:26 PM   #7
Trailer: 17ft Bigfoot trailer
Sounds like you've got it figured out.
I had a similar issue but the rot was in the floor. I found an oscillating multi-tool was great for cutting out the rot in a uniform way which allowed me to fit new material in smoothly...kind of like a puzzle. Worked great! Good luck.
Bluebamboo is offline   Reply With Quote
Old 07-24-2014, 03:49 AM   #8
Night Sailor's Avatar
Trailer: Bigfoot 3000 & Barth "slide-in" truck camper
Connecticut
I would glue in a piece of matching two of and the skin over the entire backsplash with a piece of stainless steel.
The tile idea is good too.
Night Sailor is offline   Reply With Quote
Old 07-24-2014, 07:34 PM   #9
Trailer: Bigfoot 17
Thanks for the Night sailor. I like the stainless steel idea a lot. Tiles and grout may not work very well in a moving trailer. Just trying to visulize what the kitchen would like. Airstreem or chip truck
bigfoot
Moving the Scamp's "kitchen" to the outside, freeing up Tirah Problem Solving | Owners Helping Owners 28 03-18-2009 11:03 AM
Was going to "Rip out the Kitchen" but... Dennis J. Kane Problem Solving | Owners Helping Owners 19 07-28-2007 03:10 PM
I am thinking of ripping out the "Kitchen" Dennis J. Kane Problem Solving | Owners Helping Owners 20 07-16-2007 06:11 PM
Fiberglass damage and dry rot Andrea in Oregon Problem Solving | Owners Helping Owners 17 02-15-2007 12:50 AM
Dry Rot! Legacy Posts Problem Solving | Owners Helping Owners 8 05-12-2003 07:23 PM
