13' casita axle - Fiberglass RV
Old 05-24-2009, 07:00 PM   #1
Trailer: 13 ft Casita
I just bought my first fiberglass trailer... I have a lot of things to do.. first I noticed the tires are leaning in on both sides .. it appears I have a torsion type of axle.. would this be Normal or what are the likely causes ?? it seemed to pulled ok but I think something is not quite right.. bearings or spindles worn or something...
thanks..
Phillip is offline   Reply With Quote
Old 05-25-2009, 07:26 AM   #2
Bill F.'s Avatar
Trailer: 92 Bigfoot 13.5 ft / 05 Freestar
thanks..
Hi Philip,
Don't want to be the bearer of bad news but it sounds like you may need a new axle. The rubber inserts in this type of axle deteriorate over time and allow the wheels to lean. Uneven tire wear is another indicator. If you jack up one side of the trailer you can check to see if the wheel can be moved by hand. This subject comes up regularly so you should be able to do a search under "axle" and find lots of similar stories and more info. Some trailers have bolt on axles and others are welded to the trailer frame. The bolt on type can be changed much easier than the welded type. If yours is the welded type keep a fire extinguisher handy while cutting or welding. If you don't have brakes on your trailer and you do have to replace the axle this is a real good opportunity to add brakes at minimal cost(there isn't a lot of difference in price between an axle with or without brakes). Adding brakes later is quite expensive by comparison.
Bill
Bill F. is offline   Reply With Quote
Old 05-25-2009, 10:53 PM   #3
Roy in TO's Avatar
What do you mean by leaning in? When viewed from the rear do your tires ...
look like this ?
or this ?
Old 06-01-2009, 10:16 AM   #4
look like this ?
or this ?
But...I just got back from a place here that does axles and I'm getting a new #9 axle w/brakes ... I'm having brackets welded on so the axle is a bolt on type .. axle w/brakes plus add a contoller and wired, mounted in the truck ready to go is costing about $600.
Old 06-02-2009, 10:00 PM   #5
Roy in TO's Avatar
You done very well then.
Just think when you get your trailer back the tires will look like this:
Almost looks like a smile!
Old 06-15-2009, 04:44 PM   #6
Yeeehaww, my new axle has arrived and tomorrow is the install day...
Old 06-15-2009, 05:37 PM   #7
Trailer: 1973 Compact Jr
Congratulations!
Dana T is offline   Reply With Quote
axle, casita
New Axle kentj Modifications, Alterations and Updates 1 07-05-2009 03:09 PM
Where to buy a new axle for 13' casita ? Phillip Care and Feeding of Molded Fiberglass Trailers 2 05-26-2009 05:39 AM
Casita High Lift Axle Steve R General Chat 6 09-19-2007 08:02 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
Casita Hi Lift axle Legacy Posts General Chat 6 06-08-2003 04:06 PM
